Author Topic: Jetting, a pain in the D!  (Read 15347 times)
Offline Polonda
« Reply #30 on: July 16, 2013, 02:00:55 AM »
Adjusting the air screw like above will tell you what pilot to use.  Does morse have the cr ignition advanced a bunch?  That would add low end.
« Reply #31 on: July 16, 2013, 06:57:05 AM »
I go by if the air screw is 3 turns out go the next pilot size smaller
so  it looks like you are still rich on the pilot after you get the pilot working with the air screw 1-1/2 turns out adjusted properly. Then put a bigger main jet in it then go after adjusting the needle
Dont go riding the bike WOT until you get a bigger main in it.
« Last Edit: July 16, 2013, 09:27:54 AM by rsss396 »
Offline silverlake250r
« Reply #32 on: July 16, 2013, 08:31:25 AM »
I know Johann's runs good, I have ridden it. But, a drag port is, a drag port. Ask troy how much bottom end he had with 496cc's!
2002 Roll Design Lobo MX
Offline Morse250r
« Reply #33 on: July 16, 2013, 01:02:54 PM »
My timing is stock position.  I know motor to motor you can't compare no two are the same. But mine has a very strong bottom end so much so it's hard to hold down low it likes to wheelie I'd say it has the grunt of mx style porting
88 rb racing duner
Trx 70\'s
Atc 125
« Reply #34 on: July 16, 2013, 02:56:33 PM »
^ and im jealous. I WANT THAT TOO!!!
