Author Topic: Radiator clamp request  (Read 66221 times)
« Reply #30 on: August 24, 2015, 12:19:10 PM »
Quote from: Pumashine;56956
Yes they are waterjet cut. My sample has terrible edge quality. So the outside has been extremely sanded to give it a machined appearance. :Boobies2: But the inside is a waterjet cut. Don't know who said they were billet but that is:lies: if they are saying it is machined from a solid chunk of aluminum.  By definition. A billet is a solid block of aluminum (or any material) with the size depending on the size of your desired part. The larger the desired part, the larger the billet. Contrary to casting, billet parts are created by removing excess material from the billet, essentially the part is carved out of solid aluminum. Both parts above were cut from a sheet of 1/4" aluminum.
 Typical use of the go to flashy impressionable words billet, oem, like oem, oe, factory, and many more used in misleading ways to get you.
« Reply #31 on: August 25, 2015, 12:16:43 PM »
I don't see anywhere on this clamp where it mentions patent or even pending. Sounds like more BS from Carla. Clamps have been shipped. Enjoy knowing you are not lining the clowns pockets.
« Last Edit: August 29, 2015, 12:51:59 PM by Pumashine »
« Reply #32 on: August 25, 2015, 03:09:48 PM »
Thanks for doing this guys!
« Reply #33 on: August 30, 2015, 01:15:39 PM »
Rings are spilling over everywhere
The waterjet cut edge quality is quite ruff. XXX machines the part completely on all outside surfaces,
« Last Edit: September 08, 2015, 12:04:55 PM by Pumashine »
« Reply #34 on: August 30, 2015, 04:02:34 PM »
A lil eye candy
« Last Edit: September 08, 2015, 12:01:53 PM by Pumashine »
Offline 250
« Reply #35 on: August 31, 2015, 11:06:34 PM »
Wow, looks great guys!
Offline dem3500
« Reply #36 on: August 31, 2015, 11:23:02 PM »
I kind of doubt he'd get a patent on a clamp. There's about a million different clamps out there. I'm sure this is a variation that already exists, only different part is there custom sized to fit a specific application. Besides, if there patent pending for anodized then these ones can pe patent pending for being powder coated! Ha! Put that in your pipe and smoke it! Bit$%!
« Reply #37 on: August 31, 2015, 11:48:56 PM »
Yes, there are plenty for you do it yourselfers.
« Last Edit: September 08, 2015, 02:18:04 PM by Pumashine »
« Reply #38 on: September 08, 2015, 12:12:29 PM »
Quote from: dem3500;57842
We checked with USPTO and found nothing. Ebay response was Patent Pending does not have an issued Patent #, not until the patent Issues publicly...Check with USPTO.
Even applications at USPTO have registry #'s. Until we get a # from Believing Delusional Thoughts, production will continue.
Offline dem3500
« Reply #39 on: September 08, 2015, 12:28:28 PM »
yup i specifically asked him for a patent number and he would not give me one! keep making these as long as you can!
Offline dem3500
« Reply #40 on: September 08, 2015, 12:36:23 PM »
ok this is about a 5 min read but confirms exactly what i thought! read it! its short and sweet!
http://www.ericksonlawgroup.com/law/patents/patentfaq/how-to-stop-copiers-during-patent-pending/
« Reply #41 on: September 08, 2015, 12:53:10 PM »
Quote from: dem3500;58226
Therefore, it would not be appropriate to allow patent applicants to stop others from making, using, selling, and importing the invention (e.g. patent rights) described in their patent application because it is possible the Patent Office might later determine a patent should not be granted.
 Further the copier might try to redesign the product/service to avoid the subject matter of the patent application after receiving your notice.
Occasionally a notice letter to the copier will be effective. In other instances you may need to wait until a patent is granted to take action.
Offline dem3500
« Reply #42 on: September 08, 2015, 12:57:19 PM »
^^^^^^^^^^^^^^yup!! you got it! he has no right to tell us we have to stop or he will sue us!! he can politely inform us that he has applied for a patent and give us his application number but thats it!
« Reply #43 on: September 08, 2015, 01:45:42 PM »
so what I read he is full of poo. nowhere does it say you can go after the customers.
« Reply #44 on: September 08, 2015, 01:50:11 PM »
Quote from: hickwheeler;58229
Correct and we will be handling all questions about these through PM's as he cannot use this against you.
I would not waste my time copying a patent pending article. But since this is all Hype these will soon be available to the public and sold on Ebay with the improved non patented version.
