Author Topic: Air intake tube...keep it or lose it?  (Read 5587 times)
Offline fx4pitrone
« on: July 23, 2013, 09:20:34 PM »
Still a newb w/ the trx's... just curious if most of you keep the intake tube or get rid of it and plug the inlet?  And why?
Not a racer, just trail riding and need to keep the airbox for mud and water, no lid for now, but probably an EHS cover to keep some water out, thoughts on the inlet tube?
And also, thoughts on resonator or no resonator?
Thanks guys!
« Last Edit: July 23, 2013, 09:34:34 PM by fx4pitrone »
Offline Aceman
« Reply #1 on: July 23, 2013, 09:52:54 PM »
I run the inlet and stock lid when trail riding in muddy/wet conditions.  I used the EHS on a trailride once when it was wet, took the lid off and saw water standing in my airbox and on my filter.  Not good.  Now I mostly dune so I plug the inlet hole and run the EHS again.
Arens Axis XC 310R
Houser Axis Duner CT350PV
« Reply #2 on: July 24, 2013, 08:09:21 PM »
I used to run the snorkel. I cut 1 1/2 inch slot on the passenger side of the lid for more air. Keeping it off to the side reduced the amount of crap landing right on the filter. A strip of duct tape would close the slot. Now run with no snorkel, hole plugged and the slotted lid. Good question on the resonator. Does it reduce noise with the lid off?
Offline 2strokesforever
« Reply #3 on: July 25, 2013, 01:35:40 PM »
i took all that stuff off and just made a airbox lid with Outerwears material so the carb could breathe and the filter stays clean then bought one of the Nac's racing billet airbox plugs for the hole where the snorkel went into the airbox.
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline Fear250r
« Reply #4 on: July 25, 2013, 03:55:41 PM »
I also took off my snorkel. Didn't fit with the axis rear shock. Definitely need the front hole plugged up good though. Water gets in real easy, if that's how the terrain is, and will ruin a good day of riding. NAC's plug works great if you can find one.
In house hybrid ball buster
Offline fx4pitrone
« Reply #5 on: July 26, 2013, 09:20:33 AM »
Ok thanks guys.  I do have a Nacs plug. I think I'm gonna lose the snorkel, plug the inlet, and run an EHS lid.
Thanks again
Offline atvmxr
« Reply #6 on: July 26, 2013, 09:34:14 AM »
Cheapskate tip, the screw on lids to gallon jugs of motor oil, rad fluid, washer fluid, etc etc.  some of them are a perfect fit in the snorkel hole
:stupid:
« Reply #7 on: July 26, 2013, 09:34:24 AM »
I think puma makes the pieces to make a ehs copy, just need to get some outerware material and a rubber gasket...
