Author Topic: lrd bb pipe mounting hardware  (Read 6236 times)
« on: August 07, 2015, 11:37:52 PM »
I have a lrd 350b pipe. Wondering if someone could get me the dimensions of all mounting hardware.
Thank you
« Reply #1 on: August 08, 2015, 01:29:17 AM »
pretty sure there is a 3/4" spacer at the silencer. 6x40mm bolts for the adjustment. Cant remember the length of the top hanger...4 maybe 5 inches.
Best Regards
-Jason
« Reply #2 on: August 08, 2015, 03:21:15 PM »
thanks for the info
« Reply #3 on: August 09, 2015, 12:25:58 AM »
so the lrd pipe doesn't use any rubber isolaters
« Reply #4 on: August 09, 2015, 12:20:13 PM »
They were not supplied in their hardware kit. I have never ran any with my lrd pipes. That being said, the lrd pipes are getting old at this point, so it might not be a bad idea to.
Best regards
-Jason
« Reply #5 on: August 10, 2015, 02:02:26 PM »
I just took apart the silencer for the big bore pipe. Should the core be smaller than the stinger. It is 1 1/8 od. Stinger is 1 1/8 id.
« Reply #6 on: August 10, 2015, 08:07:55 PM »
better question for Arlan. I cant remember, but I thought they used 1.25". I am unfortunately 2500 miles away from mine or I would measure. I do remember it being .125" larger than the standard bore
best regards
-Jason
Offline hontrx265r
« Reply #7 on: August 11, 2015, 09:39:14 AM »
Just all Arlan, he will probably send you hardware and you can ask him about the silencer.
« Reply #8 on: August 15, 2015, 03:15:07 PM »
started fitting it in the bike. It doesn't seem to want to clear the fender support bracket. Does it need to be run with race cut fenders?
« Reply #9 on: August 22, 2015, 04:12:53 PM »
Made may stinger for the silencer. Welds are not the greatest. But 20 years since I touched a tig torch.
« Reply #10 on: August 23, 2015, 01:34:20 AM »
Ready to rip!
« Reply #11 on: August 23, 2015, 06:58:37 PM »
Going to try and get it to the coating place tomorrow after work. So it can be ceramic coated.
« Reply #12 on: August 29, 2015, 05:33:25 PM »
got it back and mounted up.
« Last Edit: August 29, 2015, 09:08:07 PM by hickwheeler »
« Reply #13 on: August 30, 2015, 01:31:21 AM »
Bringing back memories. Very nice. When are you going to ride it?
« Reply #14 on: August 30, 2015, 10:51:51 AM »
going to try to make a day trip to sand lake in September sometime
