Author Topic: 431 puma pipe  (Read 36242 times)
431 puma pipe
« Reply #60 on: September 02, 2015, 01:35:20 PM »
That is a 100% bs spin. I am afraid direct contact is rubbing off.
I hope you feel proud of yourself Rob.
« Last Edit: September 02, 2015, 02:25:00 PM by etccb »
431 puma pipe
« Reply #61 on: September 02, 2015, 03:02:05 PM »
Quote from: KASEY;57898
well I ended up with the pipe... since I am playing with bigger toyz I needed a bigger pipe.even got to help finish it up.... ..
Thats a nice pipe Kasey, hope it works well for you. Rob seems to be the biggest azz kisser alive! Thatz the most BS I have ever heard. Any Pipe Kenny builds will eventually be boughten.
431 puma pipe
« Reply #62 on: September 02, 2015, 05:37:28 PM »
There's a reason there isn't a Selvy shop anymore either
431 puma pipe
« Reply #63 on: September 02, 2015, 06:30:35 PM »
Quote from: Skeans1;57954
I can believe that it may have taken Kenny 16 hours to build the pipe.  Lets do the math:  $600.00 / 16 hours = $37.50 per hour.  I do not know how well equipped their shop is but I could not keep my doors open if my shop rate was around $40.00 per hour.
431 puma pipe
« Reply #64 on: September 02, 2015, 06:36:26 PM »
Quote from: Jerry Hall;57956
Jerry how many hours do your #19 pipes take you to build?
431 puma pipe
« Reply #65 on: September 02, 2015, 07:36:12 PM »
Quote from: Skeans1;57957
It takes 14 to 15 hours to build the production hand coned HPR 19 pipe, silencer and exhaust flange in batches of 5 or more pipes at a time .  Custom pipes and prototypes take longer.
There are a lot of pipe builders that will knock out a tig welded hand coned pipe in 4 to 8 hours.  The majority of tig welds are fuse welded giving 50% to 80 % penetration on most of the welds.  It really slows you down when you try to get 90% to 100% penetration doing fuse welds using tig.   The tig welds viewed from the outside on most of these pipes are beautiful but the welds on the inside have sharp edges, burrs and need a lot of love in the sections where the gas velocity is high.  It takes a lot of time to make love to these high velocity areas and adds considerable cost.
We weld the majority of our pipes with a torch.  The torch produces a weld that is softer and does not tend to crack when you spend the time to make the inside of a hand cone pipe relatively smooth.  It takes a lot of time to produce a hand coned pipe that is built like the old works pipes.  The majority of the hand coned pipes being built today do not have works technology nor craftsmanship but only look like works pipe from 50 feet away.
431 puma pipe
« Reply #66 on: September 03, 2015, 01:31:10 AM »
hummm,choppy verses nonchoppy ,the COC was on to something .
