Author Topic: My new exhaust....  (Read 9429 times)
My new exhaust....
« Reply #15 on: September 12, 2015, 06:10:26 PM »
Quote from: FerrinMotorsports;58470
Jerry the only problem i had with over Rev was my fault as right before the end of the straight I would hit over rev.....I should have ran a 14 counter instead of the 13 I had on the quad....this was on a 1/5th mile oval Blue groove track......[/QUOTE
If the 13 tooth sprocket worked good at this track with similar track conditions with the old pipe set up, you probably loss a few rpms off of the top.  If this set up pulls really hard off the corners you will not need the RPMs at the end of the straight.
A 14 tooth on the counter shaft will probably be too big of a jump in gearing.  You probably need to take one or two teeth off of the axle.
Offline mrtwidster1
My new exhaust....
« Reply #16 on: September 12, 2015, 07:36:20 PM »
Nice!
Offline FerrinMotorsports
My new exhaust....
« Reply #17 on: September 12, 2015, 10:14:45 PM »
Jerry...The over rev problem at the end of the straight with the 13 tooth sprocket was due to the added torque and go it pulled mega quicker and ran out of gear....sure I could have shifted but on a blue groove track I find shifting actually slows me down....If I gear it correctly I usually scream into the turn and pitch the quad to scrub off just enough speed to power thru and out of the turn.... I guess I'm an old school racer....LOL
