Author Topic: Roll Swingarm and Pivot Bolt Bearing Issues  (Read 5606 times)
Offline bholzgen
« on: September 14, 2015, 10:08:17 PM »
I am working on an 88-89 NoLink Roll swinger and the needle bearing races have become one with the swingarm. I have tried heat and a hammer. No progress. I have a blind bearing puller that also did not move them.
My question is do Roll swingarms have some kind of stop for the needle bearings? I cannot for the life of me figure this out and I have successfully solved this issue on other swingers so its not like its my first time messing with this.
Thanks, Blake
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
Offline Hurley250R
« Reply #1 on: September 15, 2015, 09:54:21 AM »
If it's frozen from rust, I have heard Kroil is some really good stuff. Never tried it myself.
http://www.3wheelerworld.com/showthread.php/175667-KROIL-OIL-Thank-You-Guys!
« Reply #2 on: September 15, 2015, 10:20:24 AM »
Best stuff is half acetone and half atf nothing available will touch that mix for breaking rust
« Reply #3 on: September 15, 2015, 10:28:23 AM »
Quote from: bholzgen;58575
Thanks, Blake
I had this same problem. I thought my Laeger 88-89 swingarm had steps in the pivot tube that the needle bearings sat up against. Turned out they were just seized in there and I had to cut/rip them out. No step in the tube
Offline bholzgen
« Reply #4 on: September 15, 2015, 12:56:25 PM »
I ordered a needle bearing kit from Pivot Works but I'm getting the Poly bushings from atvbushings.com because I have a new hate for needle bearings.
I built this fixture from wood to help assist the pounding lol
1985 ATC 70
« Reply #5 on: September 15, 2015, 02:03:40 PM »
Chisel time. A little scarring in the tube won't hurt the new bearings. Just file/grind out any burs.
Offline dem3500
« Reply #6 on: September 15, 2015, 02:17:08 PM »
ive used a punch or crappy flat head and pounded it between the bearing OD and the swinger ID. once you get it started you should be able to split whats left and peel it out. at least ive had luck doing it that way before
Offline ytman
« Reply #7 on: September 15, 2015, 08:04:06 PM »
Just used Kroil for the first time recently. I highly recommend it. Nice fixture. Those suckers are coming OUT BABY
« Reply #8 on: September 15, 2015, 08:37:31 PM »
Kroil is Kool
Offline bholzgen
« Reply #9 on: September 15, 2015, 08:56:15 PM »
Got those damn things out. Thanks for the advice Gentleman
1985 ATC 70
Offline MTech
« Reply #10 on: September 29, 2015, 07:21:02 PM »
I know your issue was resolved, but this is what I used:
brass drift, mic'd @22mm.
beraings came right out, no drama.
Champagne taste; beer money pockets.
