Author Topic: electrical issue with harness  (Read 2891 times)
Offline pantera1975
« on: September 19, 2015, 03:22:26 PM »
I have irriidac voltage onnmy 86 ATC 250R.  Varies between 8 and 75 volts. Ive swapped everything. I did notice when I put rhe multi meter on ohms and beep I have a completed circuit when I test the green and white wires that plugs into the ac regulator it beeps my other 2 harness dont what you think.
« Reply #1 on: September 19, 2015, 04:12:27 PM »
You have a short. I don't have a diagram in front of me, but if you are getting continuity where you shouldn't then then the wires are touching somewhere.
Best regards
-Jason
Offline pantera1975
« Reply #2 on: September 19, 2015, 04:49:53 PM »
such a simple problem once I figure it out
