Author Topic: Compression ?  (Read 9025 times)
Offline Bigred
Compression ?
« Reply #15 on: July 27, 2013, 09:59:54 PM »
Ok here are numbers needle is a DG J 3rd clip down looks like 188 for a main 48 for the pilot
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Bigred
Compression ?
« Reply #16 on: July 27, 2013, 10:04:26 PM »
Another question swing arm nut I know it's a 14mm but what's the tread pitch if anyone knows
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Compression ?
« Reply #17 on: July 28, 2013, 09:01:35 AM »
Quote from: Bigred;6123
That's not a bad starting point. Fire it up, get some heat cycles in her.
Quote from: Bigred;6124
1.5 pitch.
Offline Bigred
Compression ?
« Reply #18 on: July 28, 2013, 01:19:51 PM »
Ok sweet thanks
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
