Author Topic: Setting up a charge, refill for shocks  (Read 7706 times)
« on: October 09, 2015, 09:47:31 PM »
Does anyone have a simple diagram of how the regulator and fill hose is setup. I know there is a trick to it but need to know where the bleed knob goes. Any links to the question would be appreciated or your setup and how it works.
« Reply #1 on: October 10, 2015, 12:40:34 PM »
https://www.schmidtyracing.com/product-p/n-reg-mas725-8r-w.htm   I guess the real question was how to bleed the existing shock before charging.
« Reply #2 on: October 10, 2015, 11:45:17 PM »
« Reply #3 on: October 12, 2015, 12:00:23 PM »
You bleed the existing shock by removing the schrader valve. Or were you talking about bleeding the air out in order to fill with nitrogen after filling it with oil?
« Reply #4 on: October 12, 2015, 04:48:24 PM »
Quote from: rablack21;59762
The system is usually setup with a bypass so after checking the old charge you can put what has been lost back in.
Offline dem3500
« Reply #5 on: October 13, 2015, 07:39:19 AM »
You don't need to bleed off anything. Just fill it back up if its low or let the gas out and start over
« Reply #6 on: October 13, 2015, 08:05:12 AM »
In the times that I observed shocks being serviced, the air was never bled out. The shock body was filled up with oil then sealed off. The reservoir was then filled to the top with oil, then capped off leaving no room for air. The shock was then charged to the proper pressure with nitrogen. With the right tools, it was fairly simple.
Offline dem3500
« Reply #7 on: October 13, 2015, 08:18:03 AM »
Shocks don't get the nitrogen directly on top of the oil. It goes in a separate bladder inside the reservoir. Draining the nitrogen does not drain the oil.
« Reply #8 on: October 13, 2015, 08:28:43 AM »
Quote from: dem3500;59820
That is correct. Sorry, did my post read like that?
Offline Eschonda
« Reply #9 on: October 17, 2015, 10:43:46 AM »
Quote from: Pumashine;59664
Puma What are you trying to do? 1)Check the pressure on a shock? 2) charge fill a shock after service? 3) ?????  4)  build your own tool instead of buy one?
Live everyday like it\'s your last,because one day it will be!
http://stores.ebay.com/SCHMIDTY-RACING-SUSPEN-559-804-0818
http://www.schmidtyracing.com/
« Reply #10 on: October 17, 2015, 12:26:49 PM »
Quote from: Eschonda;60043
Refill or top off nitrogen pressure.
« Reply #11 on: October 17, 2015, 12:45:17 PM »
the local shop near me charges 40$ to check an recharge shocks . an here is the bad part of this that happend .the shock shaft was worn an didn't hold the charge an they still charged me 40 $. so i am interested to know what it cost to build your own kit vs buying a complete kit an maybe a lil parts sheet if ya could.
Offline Eschonda
« Reply #12 on: October 17, 2015, 01:29:13 PM »
click on the link in my signature (schmidtyracing.com), to our website,or ebay if you are so inclined, but most products are cheaper on the website than ebay. We we sell all kinds of regulator kits, fill tools from basic to ones with many features. We also sell individual parts. Our kits are very competitive. We also sell seal kits,shock oil, springs, and quite a few different dual rate kits for UTV's as well.
Offline KASEY
« Reply #13 on: October 17, 2015, 05:32:22 PM »
worn shock shaft has no effect on nitrogen charge,,  bad shaft will let the oil out,, not the nitrogen,,
Offline dem3500
« Reply #14 on: October 19, 2015, 11:57:24 AM »
Quote from: KASEY;60057
yes what kasey said! the nitrogen is in a separate section and is not in direct contact with the shock oil.
