Author Topic: Bearing Carrier Question  (Read 5730 times)
Offline atv fan 28
« on: October 10, 2015, 09:45:12 PM »
Can someone tell me which carrier is specifically for a 250R? I have one that was in my 88 and I have another that came with a LSR swingarm I just bought. I discovered that they are different in diameter where the brake stay goes on. It's about quarter inch difference. But everything else is the same.
Offline atv fan 28
« Reply #1 on: October 10, 2015, 10:17:54 PM »
Everything else appears to be the same..... far as fitting in the swingarms, bearing size and so forth. It's just the outside diameter on the end where the brake stay plate goes.
« Reply #2 on: October 10, 2015, 10:29:59 PM »
That's  strange to me so you have different  size brake stays ?
Offline atv fan 28
« Reply #3 on: October 10, 2015, 10:33:11 PM »
Yes, the stay and the clip are a different
« Reply #4 on: October 10, 2015, 10:39:50 PM »
Can ya take some pics  an post em up  . One of the carriers  has to be from a different  Honda  atv
Offline atv fan 28
« Reply #5 on: October 10, 2015, 10:43:21 PM »
Offline atv fan 28
« Reply #6 on: October 10, 2015, 10:43:56 PM »
« Reply #7 on: October 10, 2015, 10:55:57 PM »
My opinion  is the top one is not 250r  atc or trx. I have never seen one with that much lip after  the snap ring
« Reply #8 on: October 10, 2015, 11:40:56 PM »
Is it a Banshee 40mm axle setup?
Offline atv fan 28
« Reply #9 on: October 10, 2015, 11:59:21 PM »
I don't have a clue. The one on bottom uses a single row bearing while the other has tapered bearings.
« Reply #10 on: October 11, 2015, 12:54:05 AM »
The top one is a 400ex  carrier  definitely.
« Reply #11 on: October 11, 2015, 12:55:10 AM »
Sorry  brain  don't  work well when drinking  lol. But its a 400ex
Offline atv fan 28
« Reply #12 on: October 11, 2015, 01:11:37 AM »
I have a 400EX carrier and it's the same size as the one on the bottom.
« Reply #13 on: October 11, 2015, 01:17:13 AM »
Sorry  brain  don't  work well when drinking  lol. But its a 400ex http://i.ebayimg.com/00/s/NjQwWDQ4MA==/$(KGrHqZ,!qoFDk0+SpffBQ91I1Qdlw~~60_1.JPG
« Reply #14 on: October 11, 2015, 01:36:26 PM »
I have an Lsr, Rad, and Rpm Millennium carriers. All have different diameter snouts. The lsr is the same as stock. If the carrier is different than stock it should come with the brake stay.
