Author Topic: Pwk carb.choke plunger  (Read 3469 times)
Offline Pj Uptmor
« on: October 16, 2015, 12:55:25 AM »
I couldn't get the quad to start and notice the choke plunger was loose. So my question I couldn't get it to tighten up. Is there a special position to get it too tighten up.
Thank you
Offline StrokedAZ
« Reply #1 on: October 16, 2015, 11:16:34 AM »
Do you mean the entire housing is loose or just the slide?  Does it just slide in on its own?  I'm pretty sure u can replace that part.  The atv shop near me has most of the parts to the pwk carbs.  The PO used something wrong to get the needle out of the slide of the 38mm A/S that I bought and he had two on hand.
Sent from my Galaxy S5
86 TRX 250R
« Reply #2 on: October 16, 2015, 11:35:01 AM »
threads on choke housing are plastic i think, urs may be stripped. just replace and call it good, parts are cheap.
http://jetsrus.com/individual_parts/018_500_su.html
Offline StrokedAZ
« Reply #3 on: October 16, 2015, 11:40:10 AM »
What he said lol
86 TRX 250R
« Reply #4 on: October 16, 2015, 11:35:10 PM »
The actual knob will spin indefinitely. The nut, as Jesse has pointed out, is threads into the carb.
