Author Topic: Pipe Mounting on Arens Frame  (Read 6882 times)
Offline swanitalia
« on: October 28, 2015, 09:27:58 AM »
Does anyone know how well a pipe that's made for the stock trx250r frame will fit on a Arens Bros aftermartket frame? Will my stock exhaust hangers work or will I need a different hanger?
I should have my engine all assembled by the weekend and want to start the break in process, but I am unsure how the pipe will fit.
Offline dem3500
« Reply #1 on: October 28, 2015, 10:10:55 AM »
i hade to make a front mount on my arens. the frames were not made with the same mount as the stock frames were. ill look to see if i have any pics
Offline dem3500
« Reply #2 on: October 28, 2015, 10:16:57 AM »
This is the only pic I have at the moment. Basically I welded a threaded bung to the frame to utilize the stock mount.
Offline swanitalia
« Reply #3 on: October 28, 2015, 10:26:21 AM »
Do you think if I used a piece of metal (1" x 3") to extend the mount to the hanger would work?
Offline dem3500
« Reply #4 on: October 28, 2015, 10:32:06 AM »
I think it would be mind of flimsey but it might work.
Offline swanitalia
« Reply #5 on: October 28, 2015, 10:34:43 AM »
Quote from: dem3500;60465
We have scrap pieces of 4140 steel at my work that I could take hand fulls of. I think that should be strong enough to work.
Offline dem3500
« Reply #6 on: October 28, 2015, 10:37:58 AM »
Give it a try. The only problem I can see might happen is the bolts act as a pivot point. Since the extender bracket would not be mounted in a triangle and may let the pilpe sag a little. It might work if you put some locktite to keep the bolts from getting loose
Offline swanitalia
« Reply #7 on: October 28, 2015, 10:49:17 AM »
Once I get the mounting location set I may weld a mount onto the frame to prevent the pivot problem. I'm trying to get the quad all built to get it registered and titled, then I'm planning on having you PC it after.
Offline dem3500
« Reply #8 on: October 28, 2015, 10:54:49 AM »
Sounds good!
How do you get it titled without a vin? I was wondering about doing that with mine also. Where do you live?
Offline swanitalia
« Reply #9 on: October 28, 2015, 11:03:01 AM »
Quote from: dem3500;60469
Sounds good!
You have to take it to the DMV and they will check it out, if approved they will tack a vin plate on it. I live near Almont Mi.
Offline dem3500
« Reply #10 on: October 28, 2015, 11:32:01 AM »
Ahh ok cool. I've gotten titles before with just a vin. Not bringing the quad at all. It was super easy but its good to know they will give you a vin plate.
Offline swanitalia
« Reply #11 on: October 28, 2015, 11:45:16 AM »
That's what I've been told, I have yet to truly find out if it's true. I'm trying to contact the SOS to find out more info on getting it registered and titled. I want to insure my 250r lol.
Offline dem3500
« Reply #12 on: October 28, 2015, 12:24:16 PM »
I have my R insured with state farm. It's very querky how its insured though. There's a lot to it.
« Reply #13 on: October 28, 2015, 10:36:33 PM »
Does your pipe have a lower mount by the water pump? I used stock style mounts for the 2 on the silencer, and a TM Designs banshee mount for the lower...
Pretty sure Arens were built to use stock style mounts.
Offline swanitalia
« Reply #14 on: October 29, 2015, 08:57:57 AM »
Quote from: sameltoe;60486
Yes it has a lower mount by the water pump. I might have to try the banshee mount i forgot about that hanger.
