Author Topic: 85 250r rear brake sticking  (Read 5163 times)
Offline 96motorhead
« on: November 05, 2015, 01:12:09 AM »
I have an 85 atc250r that I'm having a problem with the rear brake master cylinder.  When I press the brake lever down it sticks down until I pull the lever back up.  The return spring is fine and it doesn't require much force to pull back up.  It has done this for a few years, but i have always just pumped the brake a few times and it would work fine from then on out.  Does anyone know what parts I need to fix this or what causes this?
Thanks
« Reply #2 on: November 05, 2015, 02:28:23 AM »
Sounds like your brakes just need a rebuild. Kits are pretty cheap & fyi shindy kits are the same as oem & less money. I think it was around 50-60 to rebuild the rear caliper & mc.
Offline 96motorhead
« Reply #3 on: November 05, 2015, 10:43:14 AM »
It looks like some of the parts are discontinued like the rebuild kit.  I found a discontinued kit on ebay I'm gonna buy that and hope it fixes it.
http://www.ebay.com/itm/Honda-OEM-ATC250-Brake-Caliper-Repair-Kit-Obsolete-43520-965-305-ATC200X-/201457259929?_trksid=p2141725.m3641.l6368
« Reply #4 on: November 05, 2015, 11:50:54 AM »
I have a whole 85 atc in pieces  i took apart  recently  so i should  have the rear brakes  laying  around  if you're interested
Offline 96motorhead
« Reply #5 on: November 05, 2015, 12:31:34 PM »
I bought that rebuild kit on ebay.  If that doesn't fix it I'll consider buying a new master cylinder.
Offline pantera1975
« Reply #6 on: November 05, 2015, 11:01:22 PM »
try removing your lever and make sure it moves freely and there is no rust in between the seals too
