Author Topic: 38 airstryker questions...  (Read 15519 times)
« Reply #15 on: August 09, 2013, 09:56:05 AM »
so it will not start? as much as I dont like start fluid maybe try a little to see if it will fire, once you have it running you can determine if the pilot is to big or to small by the amount of turns on the air screw it takes to make it run properly. air screw screwed almost all the way in means the pilot needs to be bigger, 3 turns out means you need a smaller pilot
« Reply #16 on: August 09, 2013, 10:02:37 AM »
Man I sure would've thought Polanda's suggestion would be real close. Im assuming the Lectron uses a different cable than a Pwk,and if I remember right you bought a new cable with the carb. Do you think it could be a simple cable adjustment needed to make it idle? I know you said you could adjust and get it to idle.
« Reply #17 on: August 09, 2013, 10:10:41 AM »
it actually shouldnt need the cable to idle.  i am just going back to the lectron and will sell the airstryker at a loss.  now i know why some are building EFI hybrids.
« Reply #18 on: August 09, 2013, 10:18:59 AM »
Even though it is a "new" carb, try taking it apart and blow it all out. Cap sealing?
« Reply #19 on: August 09, 2013, 10:27:59 AM »
Quote from: danhung11;7843
Dumb question, how are the reeds?
reeds are good.  it will start and idle great when i put the lectron back on.  it is the airstryker that is the issue.
« Reply #20 on: August 09, 2013, 10:50:31 AM »
come on now dont just give up, struggling and figuiring it out is how you get smarter.
« Reply #21 on: August 09, 2013, 11:03:35 AM »
Quote from: rsss396;7852
Yeah John, I have had problems my new carb before. I swear the idle adjustment screw was not working on my new 39 PWK. I remember you saying the same thing. That baby had to be almost all the way in before it would idle. Thought it was strange but it worked.
« Reply #22 on: August 09, 2013, 04:45:32 PM »
thanks for all the support fellas.  i will take another shot at it.
« Reply #23 on: August 09, 2013, 04:53:01 PM »
My 39 pwk is also almost all the way in...I had to cut some of the spring off.
« Reply #24 on: August 09, 2013, 05:12:42 PM »
Quote from: sameltoe;7897
that solved it.  it runs! thanks alot everyone.  i really appreciate it.
« Reply #25 on: August 09, 2013, 05:20:18 PM »
Quote from: jcs003;7898
Now you mention it there was a thread on .net where people were buying a longer idle screw for this purpose.
« Reply #26 on: August 09, 2013, 09:58:29 PM »
Quote from: Pumashine;7899
Is the metal version longer? I remember karla saying something about one available bit never looked into it.
« Reply #27 on: August 09, 2013, 10:13:13 PM »
Quote from: sameltoe;7927
Yeah, thats where we all stopped reading. LOL  Yes the metal one had the same thread pitch but was longer in length so it would not bottom out. You had to cut the spring off and that would not have to be done with the longer screw.
« Last Edit: August 13, 2013, 11:53:01 AM by Pumashine »
« Reply #28 on: August 10, 2013, 11:46:40 AM »
this carb certainly woke up this engine.  it pulls so much better, i can ride a couple gears higher and it will pull the front wheels in 5th.  it was actually worth the aggervation.lol
another thing; couldnt get hotter than 130* or so.  thinking there is still power available.
« Reply #29 on: August 10, 2013, 11:56:17 AM »
Good deal!!
