Author Topic: 370R no link dune build  (Read 46493 times)
Offline 89Longrod
« Reply #15 on: November 11, 2015, 05:26:10 PM »
The more vertical the rear shock the better. This resembles a Cr500 linkage or any modern dirtbike rear shock set up.
« Reply #16 on: November 12, 2015, 02:23:03 AM »
Killing me with them AN fittings! Super clean!
Offline SDFab
« Reply #17 on: January 23, 2016, 11:17:28 AM »
Well didn't make my deadline. Trying not to rush this but I only get maybe an hour a week to work on it. I put the plastics and wheels on to see what it will look like. Just need to find time between other projects and work to finish.
Offline SDFab
« Reply #18 on: January 23, 2016, 11:19:57 AM »
Offline SDFab
« Reply #19 on: January 23, 2016, 11:23:44 AM »
Offline Piediddy
« Reply #20 on: January 23, 2016, 11:28:43 AM »
Good looking bike
Offline SDFab
« Reply #21 on: January 23, 2016, 11:30:02 AM »
Esr covers
And my Duncan/Roll banshee I'm rebuilding for the tenth time. I have another one that I built with a custom front end and is going a compete different route. So this one is going back to how it was before. With a fresh look.
« Reply #22 on: January 23, 2016, 11:49:21 AM »
Both bikes look great!  What front tires are you running on your R?
Offline SDFab
« Reply #23 on: January 23, 2016, 01:30:17 PM »
Quote from: havinnoj;63579
Thanks man. They are 22/7/10 maxxis razor. Had them buffed into a Mohawk for the dunes. Wanted something a little bigger and stronger then what's offered. So that's what I came up with.
Rear wheels also custom made at 5" wide. Gives the paddles a little more bite in the sand.
Offline Robsessed86
« Reply #24 on: January 23, 2016, 02:28:49 PM »
Bro I absolutely love what you've done with both quads especially the R. CUSTOM NO LINK mount looks great. The white plastics and carbon parts are sick with the beadlocks all black wheels. And cut front razors is something I haven't seen before. Genius man. That R is one sweet quad. Congrats
Offline FerrinMotorsports
« Reply #25 on: January 23, 2016, 03:26:51 PM »
Just a question on your no link set-up.... Did you slow the rebound down on your shock?....I would think you would have to at the angle your running it at to calm the pogo effect.... By having the shock angled the rebound tends to push forward on the quad more than up....That being said if you have the rebound dialed you should get some awesome traction as well as not having to run as stiff of a spring.... Keep this updated I'm really curious as to how this works for you...Awesome build by the way!
Offline Aceman
« Reply #26 on: January 23, 2016, 03:50:33 PM »
Looks great!!
Do you have an air scoop for the right side of the radiator?  How tough is it to remove the keepers for the seat pins?
Arens Axis XC 310R
Houser Axis Duner CT350PV
Offline Wrench U
« Reply #27 on: January 23, 2016, 04:23:22 PM »
SO-CAL guys are bad ass fabricators. Keep it it bro looks amazing.
« Reply #28 on: January 23, 2016, 07:44:14 PM »
Quote from: SDFab;63581
Nice - they look killer and like you say, probably get a bit more carcass thickness.  At first glance I thought they were Cascade Innovations "Cutters" http://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=12&store_dept_id=72
Offline SDFab
« Reply #29 on: January 24, 2016, 12:17:16 PM »
Quote from: Robsessed86;63582
Thanks!! I saw yours it's just as nice. My next build will be all red with 89 plastics. Was the original plan.
