Author Topic: 363 Hybrid Engineering Sphinx sold  (Read 7969 times)
« Reply #15 on: November 19, 2015, 08:25:36 PM »
Quote from: Skeans1;61117
Yes sir cash has been sent and just as excited as Mickey is.
Have to warn you these headstay heads leaked upon starting. This was my third so epoxy may or may not be in the hole for the bolt. I put this together in 2012 so you may want to pull the head and cylinder to check compression ratio and to see if this head was epoxied at the bolt hole the the headstay.
« Reply #16 on: November 19, 2015, 08:27:03 PM »
Quote from: Pumashine;61119
Tony have you ever ran them without the head stays?
« Reply #17 on: November 19, 2015, 08:32:08 PM »
Quote from: Skeans1;61120
Yes before Calvin made these ones up. I have like 3 polished heads with no head stay if you are not using it. I ended buying 3 of the new heads with the head stay option. After putting the first one on the coolant was leaking from the bolt hole. I polished them all up an then had 6 heads and 3 cylinders
« Reply #18 on: November 19, 2015, 08:33:57 PM »
Quote from: Pumashine;61121
Yes before Calvin made these ones up. I have like 3 polished heads with no headstay if you are not using it.
We'll figure it out when I pick it up Tony I'm pretty excited to try it.
Offline Saber569r
« Reply #19 on: November 20, 2015, 12:06:18 PM »
Thanks again Jared. Been over a year since got to ride my r. Can't wait. Enjoy your puma.
