Author Topic: awww man wtf  (Read 8679 times)
Offline Victork
awww man wtf
« on: December 18, 2015, 10:13:27 PM »
I'll save my question and issue for last and give the story leading up first. My plan was to race in the NECC Racing last spring but my dogs and sockets rounded off leading to a tear down, I put a near new tranny in, all new seals, bearings, clutch, and another long rod crank. So I finally close in on bolting the top end on and crack a beer about a half hr ago. I bolted the top end on and push the kicker naturally to spread the oil in the cylinder and make sure nothing is bound...well the Damon piston is now hitting the freakin head! The old crank was a oem long rod and this one is one with prox rod (109). I'm guessing I'll need to have another head cut but why did the piston clear Sith the old long rod crank and not this one? I always use oem base gaskets so that's ruled out
Offline jfwyatt1
awww man wtf
« Reply #1 on: December 18, 2015, 10:25:31 PM »
possibly a stroker crank? had that happen once to a buddy he ordered a standard long rod hot rods crank but it was boxe wrong and he got a stroker crank instead. his piston may have stuck out of the cylinder more than yours hard to tell with a pic. just a thought.
awww man wtf
« Reply #2 on: December 18, 2015, 10:32:53 PM »
A  bigger spacer plate.  They  are available. Problem solved !
Offline Victork
awww man wtf
« Reply #3 on: December 18, 2015, 11:05:05 PM »
Go up to the next size spacer plate? I don't get it is the pro x a small amount longer? Oem crank the rods on doesn't look modded other than being welded on the pin
Offline Piney0
awww man wtf
« Reply #4 on: December 18, 2015, 11:23:40 PM »
Is that an 85 / 86 style piston in there?  how thick is the spacer plate, and how thick are the gaskets?
awww man wtf
« Reply #5 on: December 18, 2015, 11:29:23 PM »
i would measure what ya got sticking out add that to the plate ya have an see what ya come up with also stick with what brand base gaskets ya got that could change things also , check esr website for spacer plate thickness needed .if not avalible they can be  cut. if ya got a 4mil stroker  it should be easy to figure out after measured
Offline Victork
awww man wtf
« Reply #6 on: December 18, 2015, 11:34:14 PM »
I used oem gaskets last time and also this time so it's not the gaskets. The piston is the same one it only had like 10 hrs on it. So I have oem gaskets again, and same piston/spacer plate. I honestly think the pro x rod is a small bit longer because when the cylinder was snug right before I cranked it down it wasn't bound, only when it was cranked tight
Offline Victork
awww man wtf
« Reply #7 on: December 18, 2015, 11:45:40 PM »
Spacer is approx 3/16
awww man wtf
« Reply #8 on: December 18, 2015, 11:45:52 PM »
i would get ahold of esr or  maybe jerry hall will chime in an have a answer . I'm not fimiliar with all the diff. rod brands length's. i would just get a measurement an go from there.
awww man wtf
« Reply #9 on: December 18, 2015, 11:47:20 PM »
i dont have my 4mil motor here but my spacer is closer to 1/4
awww man wtf
« Reply #10 on: December 19, 2015, 12:34:27 AM »
You have it apart that far would not be hard to measure the stroke. But if it is a stroker crank I thought there is same clearance issues that have to be addressed.
Offline spiritaces
awww man wtf
« Reply #11 on: December 19, 2015, 05:09:18 AM »
It's guaranteed a long rod crank. Bubba put that together for me.
Offline Victork
awww man wtf
« Reply #12 on: December 19, 2015, 07:49:23 AM »
I don't doubt it is Jon, I just don't get how the piston touches the head now. I guess I'll try a 5mm spacer and see what happens
awww man wtf
« Reply #13 on: December 19, 2015, 10:14:00 AM »
Quote from: Victork;62074
The 5mm or .188" spacer are the same. You will need the 1/4" spacer. http://www.tlr-online.com/trx250r/spacer_plates
Offline Victork
awww man wtf
« Reply #14 on: December 19, 2015, 08:40:48 PM »
Payment sent let's give it a try tony
