Author Topic: New Project: YFZ/Banshee Hybrid  (Read 79996 times)
Re: New Project: YFZ/Banshee Hybrid
« Reply #120 on: May 12, 2017, 05:33:29 PM »
well, i await a new throttle valve from japan.  at its current state the bike is excessively rich, and the new slide is intended to solve this, at one degree.  the other degrees of incidence, will likely be resolved via, dyno tuning at Hetrick.
i will run the pod style filter until i can dyno tune.  I learned a lot about intake and exhaust signals because of Jerry setting me straight. those pulses mean everything.  with that said, my long (orange) intake tube is not out of the question of producing power.  more work is needed.
« Reply #121 on: July 07, 2017, 04:44:56 PM »
i finally received the carb and it is rich, extremely rich, however it will not really rev out.  i am now believing that john tabata is correct.  I just need to admit the old woods set-up from the 90s is very limiting.
my new approach is:  2 carbs and 2 pipes.
Offline JohnTabata1
« Reply #122 on: July 08, 2017, 10:12:48 AM »
LMK if you need any help
« Reply #123 on: August 04, 2017, 04:54:14 PM »
putting on the 28mm PWKs here soon.  trying to find pipes, so i don't need to do modifications of T5s or something like that.
any suggestions?
« Reply #124 on: November 14, 2017, 05:26:01 AM »
I have a set of pipes coming from mat shearer and this should be complete by spring.
