Author Topic: New Project: YFZ/Banshee Hybrid  (Read 78684 times)
« Reply #75 on: September 12, 2016, 04:44:26 AM »
Quote from: Langbolt;69518
Hey John, It looks like your Carb is way to tilted forward.....you need to get the float bowl level so the carb will work properly.....you might be either too lean or too rich with the set up you are currently running.....Maybe find an angled boot ? Did the Exciter have a straight boot ? Maybe another  Snowmobile boot  may work better ?
I considered that.  I found out why it wasn't running correctly.  in the one image, above you can see two small holes in the intake.  I forgot to plug them.  once I plugged them it idled ok.
with that said, i would like to find a different boot as to make the connection to the airbox boot easier.  a custom 3D printed piece might be my only option.
« Reply #76 on: September 12, 2016, 05:54:19 AM »
Quote from: Skeans1;69500
When I had my banshee one side would be leaner or one side would richer with a two into one, and there's guys that have burned down the motors with the singles.
I agree, this can happen.  I know a big issue is those who were using the trinity piece which is junk.  people would also have their engine fail due to using a single carb with a dual exhaust.
the exciter 2 into 1 with a 2 into 1 exhaust has been a proven trail set-up; kim kuhnle ran this set-up for years.  it might take some work to dial it in but thats parts of doing something custom.
« Reply #77 on: September 13, 2016, 05:24:10 AM »
Here is the bike idling:
[video]https://youtu.be/gnoWOndAOLg[/video]
let me know what you think.
« Reply #78 on: September 17, 2016, 08:30:48 AM »
custom chain slider (prototype):
« Reply #79 on: September 23, 2016, 06:20:12 AM »
looks like a backfire caused this damage:
I believe this was caused from the use of a cheap $13 coil to troubleshoot wiring.  any other thoughts?
John
« Reply #80 on: November 29, 2016, 12:51:28 AM »
[MENTION=77]jcs003[/MENTION] any luck on this?
« Reply #81 on: November 29, 2016, 04:55:06 AM »
I made progress.  I think the smart carb is the problem.  I tried 5 different metering rods and got no real improvement.  I tried my 38 a/s off the 250r and it ran better despite the carb set up for a a bigger cylinder.  I got a 35 a/s on the way.
« Reply #82 on: November 29, 2016, 09:59:01 AM »
Quote from: jcs003;70981
I'll bet money the Smart Carb was your back fire reed killer John, only way they may work is with two one to each cylinder. If you're running a 2 into 1 how is it a smaller cylinder set up then your R?
« Reply #83 on: November 29, 2016, 10:37:08 AM »
Skeans, it is 2, 175cc cylinders so the carb feeding 250r is jetted fat for the 175.  I could be wrong in my logic.
« Reply #84 on: November 29, 2016, 03:24:52 PM »
Quote from: jcs003;70983
Each cylinder is 175 but you're feeding two cylinders with one intake so you're feeding 350cc of displacement.
« Reply #85 on: November 30, 2016, 08:37:16 AM »
Well smart carb is sending new metering rods and with the 35 a/s I should be able to work it all out.
« Reply #86 on: November 30, 2016, 09:44:16 AM »
Quote from: jcs003;70999
I finally gave up on mine couldn't keep it in adjustment with the elevation changes between my place and the coast then throw humidity into the your were sol. On the puma they claimed it was the vibrations from the motor that was causing the issues if a carb is so tight on tolerance that light vibrations mess it up why is it in motorsports? Hope it all works out for you John but if it was me I'd ask for a refund and get out and play.
« Reply #87 on: November 30, 2016, 09:54:57 AM »
Skeans that will be my move if the smart carb doesnt workout with the new rods.  Corey brought up the tight tolerance thing to me too.  Apparently it is a very sensitive carb.  I am just tired of fooling with it.
Offline JohnTabata1
« Reply #88 on: November 30, 2016, 03:37:09 PM »
Banshee mtrs work best one carb per piston
« Reply #89 on: December 02, 2016, 12:14:47 AM »
You should of ordered 2 35A/S carbs. I got a 39pwk feeding my 67mm oem cylinder & your wanting to feed a modified 350 twin with just 35mm?
