Workshop
Engine and Bottom End
Which reed valve is better?
Topic: Which reed valve is better? (Read 3850 times)
supernutt
Total likes: 2
July 28, 2013, 02:22:17 PM »
Got a vforce 3 valve and what I think is a vforce 2 valve. Reeds appear to all be in good shape. Which one should I use on a well ported 250? [ATTACH=CONFIG]1073[/ATTACH]
Last Edit: July 28, 2013, 03:10:07 PM by supernutt
97 Laeger XC narrow CR500 link +4 t-pin
christph
Witch reed valve is better?
July 28, 2013, 03:24:47 PM »
There are several differences between the V-force 2 and 3. The 3 uses clips rather than screws to hold the reeds in and it has an aerodynamic insert on the intake side that is supposed to improve the flow rate. If I had to pick one I'd pick the 3 just because they claim it represents an advance over the previous design. You may want to test them back to back. I've had them both and haven't notice a seat-of-the-pants difference.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
supernutt
Total likes: 2
July 28, 2013, 03:36:18 PM »
Sounds like a good idea. The 3 is newer anyways.
xTHUNDERCATx
July 28, 2013, 03:50:18 PM »
In banshees I know quite a few builders like the v-2's for top end performance, v-3's for lower range. Im not sure if its the same with the small design changes there would be between the quads but it may be something to consider.
supernutt
Total likes: 2
July 28, 2013, 03:53:09 PM »
I need all the help I can get for bottom end. I weigh 250lbs and it has to get my butt moving!!!
BJR88250r
July 28, 2013, 04:10:12 PM »
I run the 2's seem to give a broader powerband I thought when compared to the 3's. The 3's also lost a upper reed petal on me into the motor. Hard tellin if there was a diff between the two just felt like that to me.
Workshop
