Author Topic: Spark Plug  (Read 5695 times)
Offline zcarlson12
Spark Plug
« on: July 28, 2013, 07:02:05 PM »
What are you guys running? I did some research already but it seems like everyone uses either the b8es or the b9es. My motor is a ESR 310 if that matters. Thanks.
Spark Plug
« Reply #1 on: July 28, 2013, 07:13:32 PM »
runnin the sandunes I allway run 9s.really suppose to use the ground strap to determine the heatrange .more horse power ,colder plug
Spark Plug
« Reply #2 on: July 28, 2013, 07:23:15 PM »
Quote from: fearlessfred;6237
This is true but if you are jetted rich the 9's will foul plugs more often. I'm lazy and use the 8
Offline zcarlson12
Spark Plug
« Reply #3 on: July 28, 2013, 08:25:00 PM »
Thanks guys. I'll be doing mostly woods and mx.
Spark Plug
« Reply #4 on: July 29, 2013, 01:44:49 PM »
with the cr ignition its difficult to foul plugs, even if rich.  so it would be the 9 with the cr250r ignition.  with stock its safer to use an 8 in my experience.
Spark Plug
« Reply #5 on: July 29, 2013, 03:52:38 PM »
BR9EIX is what i'm running. Works great, no fouled plugs as of right now.
Spark Plug
« Reply #6 on: July 29, 2013, 04:02:05 PM »
Quote from: Tbone07;6335
Mr.PC2000
That's the only plug we can use I believe.
Offline PORTED R
Spark Plug
« Reply #7 on: July 30, 2013, 03:57:43 AM »
No good luck with 9's,but I jet rich
I always use 8's
McCoy ProX 350 5mil Duner
Offline mx250r91
Spark Plug
« Reply #8 on: July 30, 2013, 05:08:48 AM »
BR8EG, also this is the specd plug for 00-01' CR250s
Offline zcarlson12
Spark Plug
« Reply #9 on: July 30, 2013, 08:21:39 AM »
Thanks for the info guys. Ordered a bunch of 8's yesterday. I looked at what plug I was using and it was a 9 so I guess I'll see which works better.
Spark Plug
« Reply #10 on: July 30, 2013, 09:23:17 AM »
Quote from: sameltoe;6336
Mr.PC2000
We must be speshul :excitement:
