Author Topic: Huge quality engine lot -polished, hinson, oem crank, cr 250 ign, esr carb, pwr  (Read 10756 times)
Offline teddy250r
Good Afternoon,
I am parting out a fresh bottom end.  I had less than 5 hours on this engine and has been sitting (lubed/wet) for 2 years, everything was fresh from the bearings to the seals, etc and top quality with OEM parts used primarily.  Everything is in excellent condition, some of you might know me from some of the other forums and can vouch for me--I do nothing half-a**ed, ever.
I am open to reasonable offers, but please be respectful as I know what these are worth.  Please be patient as I will be adding a slew of picures tonight, but my flywheel puller has disappeared so I won't be able to get detailed internal pics until the new ones comes in the mail.  Likewise I won't be able to ship some of the parts until that time when I break the engine down.  I'm sure I'll also be adding parts as I go along, so please keep checking back.
Pricing below does include shipping to the CONUS, but does not include the paypal fees--please pay them or add 3% to the below prices.
Polished matched cases with fresh bearings/seal (primarily OEM) $425
OEM rebuilt stock stroke crank with OEM KTM 132MM rod $150
2001 ESR/CR 250 Ignition SOLD
PWR polished aluminum radiator $300
Mikuni/ESR TMXX 40.5mm taper bored $150
Polished oem clutch cover/water pump (fresh OEM internals) & polished allen bolts $175
Polished OEM Stator Cover (small groove where shifter rubbed) & polished allen bolts $30
Complete '88-'89 transmission with shift drum and forks $250
Hinson Clutch basket w/ OEM gears & pressure plate (I'll include oem plates/springs/fibers if you want them) SOLD
Kick start gears/return spring/shaft $30
Zinc plated polished OEM Kick start lever SOLD
OEM rebuilt counter balancer $50
RPM billet adjustable timing plate $45
Please feel free to ask any questions
« Last Edit: January 20, 2016, 02:00:23 PM by teddy250r »
Offline teddy250r
Here is a pic of the engine before tear down
Offline DoodyCallsrva
Pm sent
Offline jadleybray
Teddy has been around for as long as I've been on the forums, long before facebook.  lol
Offline teddy250r
Ignition complete and in great shape. ESR CR 2001
Offline teddy250r
RPM adjustable timing plate
Offline teddy250r
Clutch and stator covers
Offline teddy250r
Kicker and shifter
Offline teddy250r
PWR rad with OEM guard on the front. A few bent fins on the back but overall excellent condition.
Offline teddy250r
ESR taper bored 40.5 Mikuni tmxx excellent condition
Offline teddy250r
ESR Airbox eliminator $ 35
Polished OEM throttle and good cable
$50
Offline teddy250r
I will post pics of the cases as I tear down, but as you can see this is the best pair you can find right now that are OEM. Every inch show polished, no spline damage, no repairs, no BS! All fresh bearings/seals on the inside with OEM used where available.
Offline teddy250r
Also the cases are machined to accept a BB cylinder
Offline teddy250r
Clutch basket, pressure plate, etc some very slight grooves in the basket (normal) but excellent condition
Offline teddy250r
Inside of the clutch cover
