Author Topic: Anyone figured out a lighting option for the CR250 Ignition?  (Read 19792 times)
Offline hunter7389
« Reply #15 on: May 28, 2016, 10:09:53 AM »
Unless...you know... you ride at night
Offline jto1
« Reply #16 on: July 10, 2016, 07:49:24 PM »
I used electrosport esl990 lighting stator with stock trx headlight, and ac rectifier, and it works flawlessly. No battery needed. May not be what your looking for, but it's an option, and works pretty darn well for me.  For me it's plenty of light with the high beam on, and requires no modification. Ran it to stock light, and switch.
Offline jto1
« Reply #17 on: July 10, 2016, 07:54:40 PM »
Offline Dirt man
« Reply #18 on: July 11, 2016, 03:10:38 AM »
I bought the Rickey stator battery, used cr 500 lighted stator with the fixed cdi which is around $500.(used).  I was running baja designs 8" and 10" led bars and a small led taillight.  I had the 8" and tailight on one switch and the 10"  on a separate switch.  The battery would not power the 8" and 10" at the same time with the engine off,  but powered them both perfectly with the engine running. I used this setup for probably 3 hrs of night riding and while about 3 hrs into a day ride (lights off)  the stator quit giving spark and left me stranded. The cr 500 stator would backfire on shutoff, would not start as well or deliver all around power as well as the cr 250.
It goes fast over bumps too!
Offline dem3500
« Reply #19 on: July 11, 2016, 02:35:06 PM »
i havent looked too far into it but i think using the 02+ cr250 ignition you can use the power valve power to light a led. or atleast use it like an alternator. like i said i havent looked too deep into it so dont quote me on anything
Offline atvmxr
« Reply #20 on: December 18, 2016, 08:26:36 PM »
Bumping this up again.  Has anyone found a good solution?   A guy on one of the Facebook pages said he's been running cr ignition with lights for about a year.  Maybe one of you even.
Anyway, he said he could make kits for anyone interested FYI
« Reply #21 on: December 18, 2016, 08:49:21 PM »
Quote from: atvmxr;71197
Post a link please
Offline atvmxr
« Reply #22 on: December 18, 2016, 08:56:34 PM »
It's jake on this site.  I sent him your email address.
« Last Edit: December 18, 2016, 09:22:13 PM by atvmxr »
« Reply #23 on: December 18, 2016, 10:15:13 PM »
Quote from: atvmxr;71199
Yes thanks, he sent me the link for the light setup.
« Reply #24 on: December 18, 2016, 10:21:50 PM »
Quote from: Pumashine;71202
[MENTION=74]traxman[/MENTION] seems like he had a lighted cr Tony.
Offline Stater212
« Reply #25 on: March 03, 2017, 07:47:47 AM »
I too would like to know how to set this up.
« Reply #26 on: March 03, 2017, 08:57:31 AM »
Would like imfo on this to
Offline jto1
« Reply #28 on: March 03, 2017, 09:50:38 AM »
Thanks , but cannot view link i do not have fb
Offline jto1
« Reply #29 on: March 03, 2017, 10:25:45 AM »
Quote from: thesmith87250r;72141
Sent you a pm, I can help you out.
