Author Topic: 88 upper radiator shroud mounts  (Read 3972 times)
Offline stevo936
« on: February 02, 2016, 10:08:42 PM »
The mounts on my 88 250r shroud keep breaking.  Ive tried to weld them a few times but usually break again shortly after.
Ive seen the mounts on eBay for 86s for like $20.  Will these work on my 88 style?
Offline mandom250r
« Reply #1 on: February 02, 2016, 10:16:18 PM »
are you using rubber cushions on the mounts for vibrations?
« Reply #2 on: February 02, 2016, 11:55:36 PM »
That is odd. I have broke shrouds before, but not the mounts.
« Reply #3 on: February 03, 2016, 12:24:10 AM »
maybe its the person welding it ? most likely the the metal is weak an keeps beaking where the weld is ? i have a 89 parts frame i just might  have the tabs you are looking for. pm me if  ya need mounts
Offline stevo936
« Reply #4 on: February 03, 2016, 01:16:13 AM »
Ill see if i can take a picture and show you guys where its breaking tomorrow
« Reply #5 on: February 03, 2016, 08:37:48 AM »
Quote from: stevo936;64102
The mount it very thin and cannot withstand alot of weight or vibration. The ones supplied in the gusset kits are 3 x the thickness for this purpose.
[/QUOTE]
You can always cut them off and put on the 86 style.
« Reply #6 on: February 03, 2016, 12:27:56 PM »
Quote from: Pumashine;64113
You can always cut them off and put on the 86 style.[/QUOTE]
If you are gonna weld some back on, go with Tony's kit. The oem ones are far too weak.
