Author Topic: Modifying 5b cm?  (Read 7504 times)
Modifying 5b cm?
« on: February 06, 2016, 03:15:28 PM »
Well since my cm is not selling thinking about making it a standard mount. Question is should I use standard size stinger like ESR does or do I make it a true bb for my 330? So what are your guys thoughts.
Modifying 5b cm?
« Reply #1 on: February 06, 2016, 04:59:05 PM »
What do ya need to do to make it non center?  Is it a easy cut an reweld ?
Modifying 5b cm?
« Reply #2 on: February 06, 2016, 05:40:51 PM »
I will get new stringer material. Then bend and weld in a new piece
Modifying 5b cm?
« Reply #3 on: February 06, 2016, 05:43:32 PM »
Ok so the only  difference is the stinger  pipe that should be very simple.
Modifying 5b cm?
« Reply #4 on: February 06, 2016, 05:44:52 PM »
At least I think so. Will not know for sure until I do it.
Modifying 5b cm?
« Reply #5 on: February 06, 2016, 05:48:54 PM »
Wonder if it as simple  as cutting the stinger pipe an just flipping it  ? An some small modifications?
Modifying 5b cm?
« Reply #6 on: February 06, 2016, 05:51:00 PM »
I think it needs more of a bend in it
Modifying 5b cm?
« Reply #7 on: February 06, 2016, 05:53:33 PM »
Possible  ya take it to a exhaust shop with a tube bender an get the bend ya need ?
Modifying 5b cm?
« Reply #8 on: February 06, 2016, 05:55:44 PM »
I have a tubing bender
Offline Wrench U
Modifying 5b cm?
« Reply #9 on: February 06, 2016, 09:20:53 PM »
Your better of cutting it. It's difficult to bend pipe and not alter inner ID. Thats why mandrel bender are so popular/ expensive in any performance application, cause the inner ID does not change. Never seen a mandrel bender that small in diameter and I worked in exhaust shop for many years. There r other options to try for dirt guys.
Offline Wrench U
Modifying 5b cm?
« Reply #10 on: February 06, 2016, 09:30:08 PM »
I would use aluminum tubing, cause it's easier to manipulate with less pipe distortion/collapse. Try find something with a thick wall, that will let it stretch material an not get to thin. I would use a socket secured in a vice and heat, metric sockets will get u really snugg fit. I use to MAKE stuff work! Lol!!
Modifying 5b cm?
« Reply #11 on: February 06, 2016, 09:41:46 PM »
I have a proper tubing bender. Not a pipe bender. Will be made out of steel so can be welded in place of piece I remove off pipe
Offline Wrench U
Modifying 5b cm?
« Reply #12 on: February 06, 2016, 09:47:49 PM »
Proper tubing bender makes the difference. You'll be good then. Most people don't know the difference.:buddythings0002:
Modifying 5b cm?
« Reply #13 on: February 06, 2016, 09:58:26 PM »
Ya I have a pro tools 105hd with dies from 3/4" to 1 3/4"
Offline Saber569r
Modifying 5b cm?
« Reply #14 on: February 06, 2016, 10:25:24 PM »
Pm jerry hall he does this he recommended the bigger mod on my old trx11 pipe. I'm sure he could give some good advice.
