Author Topic: List of Big Bore Pipes - 1-1/8" Stinger Diameter - TRX250R  (Read 18707 times)
« on: February 09, 2016, 09:26:12 PM »
Starting this thread based on Chat Box convo regarding companies who manufacturer "big bore" 250R pipes - specifically those with a stinger inner diameter (I.D.) equal to 1-1/8" (1.125").  Standard pipes have an I.D. of 1".
With that said, please feel free to post up additional pipes until we have a comprehensive verified list.  Post up what ya got and I will edit the master list.  Eventually this would make a nice sticky or Tech Article.
How about FTZ, Trinity, CT, PSI, etc.?
CPI Racing
  • Puma Inframe
Curtis Sparks
  • 330 HR (need to verify)
  • 330 MX (need to verify)
  • BB TT?  (what was the actual name of this - it is hand coned).
LED Performance Engines
  • 350G Team
  • Puma Pipe (Gen 1 - circa ~????)
  • Puma Pipe (Gen 2 - circa ~ 2014?)
LRD Performance
  • 350B
  • 350D?  (?? possibly the successor to the 350B?)
Shearer
Note that stinger diameter is not the only thing to consider when looking at a BB pipe.  "Big Bore" can be relative - for example, ESR's TRX11 pipe is considered a BB pipe for motors up to 370cc.
Related Info for future..
http://trx250r.org/threads/6998-Modifying-5b-cm?p=64291#post64291
« Reply #1 on: February 09, 2016, 09:32:49 PM »
Quote from: havinnoj;64366
With that said, please feel free to post up additional pipes until we have a comprehensive verified list.  How about FTZ, Trinity, CT, etc.?  Post up what ya got and I will edit the master list.  Eventually this would make a nice sticky or Tech Article.
CPI Racing
  • Puma
  • Packard Pilot cylinder
Curtis Sparks
  • 330 HR
  • 330 MX
  • 350G Team
LRD Performance
  • 350B
Shearer
  • Puma drag, torque, and center mount
  • Sphinx drag and torque
Hope there's more
Offline Michael88R
« Reply #2 on: February 10, 2016, 12:25:22 AM »
Esr added a B to the part number of most of their pipes. Eddie told me it stood for big bore. They still have the small stinger id but the head pipe is bigger diameter.
« Reply #3 on: February 10, 2016, 10:06:01 AM »
Quote from: Michael88R;64376
Thanks.  Maybe it would be good to expand this list to a few different categories - ones with 1-1/8" stingers and others that are built for (the fairly ambiguous term) "Big Bore" motors.
« Reply #4 on: February 10, 2016, 11:01:59 AM »
I know this post will get "corrected" by a certain someone soon but I am going to make it anyway. A lot of people are believing they need a larger stinger when they don't necessarily need it. Big bore or bb does not mean big stinger. As an example the esr b bb pipes lower the temps over standard pipes and there is another well known pipe builder who also uses a standard size stinger with his pipes for 370ish bb engines. There is more to it from flange to stinger tip then just the stinger size and the thought that a 330 to 370 needs a larger stinger is not always correct. There is a give and take to the stinger size as part of the total package or a cr125 would have had the cr250 size stinger and a cr250 would have had the cr500 size stinger etc. Someone attempting to make you think a pipe builder is wrong and does not know what they are doing if they use a std size stinger on their bb pipes for 330 to 370 bb 250r engines is what is wrong.
>>>>>"IMO"<<<<<
edited
« Last Edit: February 12, 2016, 10:20:04 AM by etccb »
« Reply #5 on: February 10, 2016, 11:49:53 AM »
Quote from: etccb;64390
I know this post will get "corrected" by a certain someone soon but I am going to make it anyway. A lot of people are believing they need a larger stinger when they don't. Esr b pipes lower the temps over the previous standard pipes and there is another well known pipe builder who also uses a standard size stinger with his pipes for 370ish engines. There is more to it and a 330 to 370 needs a larger stinger is not always correct. There is a give and take or a cr125 would have had the cr250 size stinger and a cr250 would have had the cr500 size stinger etc. Someone attempting to make you think a pipe builder is wrong and does not know what they are doing if they use a std size stinger on pipes for 330 to 370 bb 250r engines is what is wrong.
>>>>>"IMO"<<<<<
Yes there are a couple schools of thought on this.  What you're describing was referenced in the link I posted in the original post.  And to be clear, this thread wasn't created to discuss which setup was/is better - it's just to document pipe options with 1-1/8th stinger tubes for reference.
Offline fast350r
« Reply #6 on: February 10, 2016, 01:11:03 PM »
My cpi puma inframe , has the 1 1/8 stinger?? its a hand coned but I don't know if it has a certain name imposed by Mike at CPI
Shearer 431 puma
« Reply #7 on: February 10, 2016, 01:19:27 PM »
Quote from: fast350r;64396
Thanks - I just added it as "Puma Inframe" for now.
Offline spiritaces
« Reply #8 on: February 10, 2016, 07:53:47 PM »
Well my builder says I need a big bore and I'll have to just take his word for it. Don't matter anyway since I needed a pipe so might as well get what is recommended
Offline Michael88R
« Reply #9 on: February 10, 2016, 09:54:24 PM »
Quote from: spiritaces;64412
That's the best. Find a builder that u trust and do what he says.  Finding the builder that u trust is the hard part.
« Reply #10 on: February 12, 2016, 12:37:15 AM »
Dynoport???? I wonder what they offer? i'll make the call and post up what I find out.
Offline spiritaces
« Reply #11 on: February 12, 2016, 01:05:24 AM »
Rich Daly (Dynoport) offers bb pipes I know that for sure
Offline The_Steve_Man
« Reply #12 on: February 12, 2016, 03:14:27 AM »
I have an LRD adjustable pipe for an ATC that is bb.
« Reply #13 on: February 14, 2016, 12:56:33 AM »
I thought I say somewhere someone had a big bore trinity
Offline Michael88R
Re: List of Big Bore Pipes - 1-1/8" Stinger Diameter - TRX250R
« Reply #14 on: March 03, 2020, 11:36:18 PM »
Unfortunate this thread didn’t get more results.  Hard to know what to do on stinger size if you r in the 330-370 cc range.  Anyone know the stinger size for the following pipes?
New Esr trx10
Ktm 380 dirt bike OEM
