Author Topic: Study of squish action by Neels van Niekerk  (Read 4115 times)
« on: July 30, 2013, 04:13:47 PM »
copied from here:  http://home.earthlink.net/~scloughn/id21.html
[TD=colspan: 2]Squish action[/TD]
[/TR]
[TR]
[TD=width: 698, bgcolor: #336699, colspan: 2][/TD]
[/TR]
[TR]
[TD=width: 698, colspan: 2][/TD]
[/TR]
[TR]
Study of squish action by Neels van Niekerk, author of EngMod2T engine simulation software
Vannik Developments
2stroke and 4stroke simulation software
[/TD]
[/TR]
[TR]
[/TR]
[TR]
Some Thoughts on Squish Action
                           1. Introduction
                           During the last 20 years, but more so during the last 18 months I have been
                           taking an intensive look at the effects of squish. This is part of an attempt to
                           include a combustion model into simulation software where the model
                           calculates its parameters rather than having it prescribed by the user.
                           Determining the values to prescribe combustion accurately one requires a
                           fairly sophisticated engine test cell with the capability to record combustion
                           pressure traces. As part of this exercise I have changed my views on squish
                           quite a bit. Some of what I found will be described next.
                           2. Turbulence
                           Discussing squish without first taking a brief look at turbulence is a waste of
                           time as the main function of squish is to increase the turbulent intensity in the
                           combustion chamber. Without turbulence in the combustion chamber we
                           would burn the mixture at the laminar burning rate which is ten to twenty
                           times slower than the turbulent rate. This would make practical engines that
                           rev higher than about 1500rpm an impossibility.
                           Turbulence in a 2stroke engine is caused by three mechanisms. The first and
                           most important of these is the scavenging process. The kinetic energy of the
                           inflowing scavenge streams is converted at a specific rate to turbulent kinetic
                           energy which leads to an increase in turbulent intensity. At the same time this
                           turbulent intensity is being damped out by the viscosity of the fluid (air/fuel
                           mixture) and converted to heat. From this there follows at least the following
                           two conclusions:
                           • The turbulence generated by the scavenging process influences the
                           combustion rate so it is to be expected that a 2port system will have
                           different combustion characteristics from a 7port system.
                           • The faster an engine turns the less time there will be for the turbulence
                           to be damped out by the viscosity thus increasing rpm will, inside
                           some limits, increase the burn rate provided that the turbulence created
                           by the scavenging process does not decrease faster with the increase in
                           rpm.
                                                       The next generator of turbulence is the piston movement. As the piston
                           displaces fluid during the up stoke it imparts kinetic energy to the fluid which
                           gets converted at a certain rate to turbulence. Obviously this increases with
                           rpm so higher rpm will have a higher turbulent intensity and thus faster burn
                           rate unless the dissipation rate is greater than the generation rate.
                           And then, the third generator of turbulence is the squish action. The squish
                           action causes gas to flow towards the center of the cylinder. The speed of this
                           flow is what we calculate with various pieces of software and is known as
                           MSV or maximum squish velocity. Now to repeat what has been said in the
                           previous two paragraphs; this kinetic energy is converted to turbulence at a
                           rate depending on the conditions inside the cylinder at that time. Also, MSV is
                           a function of squish band geometry and rpm. This leads to the following
                           conclusions:
                           • As rpm increases so does MSV, and so does the available kinetic
                           energy that can be converted to turbulent intensity. If this does get
                           converted the burn rate will increase.
                           • As the squish area ratio increases and or the squish clearance decreases
                           the MSV also increases with the same results as for the previous point.
                           The picture that emerges from this is that depending on the residual turbulence
                           in the cylinder at the time of the squish action, the squish action can either
                           increase the turbulent intensity or have no effect on the turbulent intensity.
                           This can translate into some of the following:
                           • On an old 2stroke with two transfer ports and high primary
                           compression the squish action can increase the burn rate so much that
                           maximum pressure occurs so early that a large amount of negative
                           work is done, a lot of heat is generated and power is lost unless the
                           timing can be adjusted. On older engines that can sometimes not be
                           done so a squish head is detrimental.
                           • On some engines the increased turbulent intensity can shorten the burn
                           times after max power so much that it kills over-rev. On others where
                           the burn time was too long it can improve over-rev.
                           • If the port and pipe combination is a bad mismatch that looses a lot of
                           fresh charge (and thus kinetic energy) during the open cycle increasing
                           the MSV will usually help such an engine and vice versa.
                           There are many more such examples but the general trend is clear: Without
                           knowledge of the turbulent intensity inside the combustion chamber at the
                           time of combustion it is not possible to say whether the engine needs more or
                           less squish.
[/TD]
[/TR]
[/TABLE]
« Reply #1 on: July 30, 2013, 04:14:31 PM »
3. Squish Action
                           There are unfortunately not many papers published on squish action, mostly
                           because in most 4strokes it is of lesser value. They have to make space for
                           valves which is more important. They do however generate turbulence
                           through tumble and swirl which is not really practical for loop scavenged
                           2stroke engines. There is one class of 4stroke engines that use squish though
                           and that is the diesel engines with the bowl in piston type combustion
                           chamber. Measurements on these engines have shown that the calculated
                           squish velocity using the MSV equations corresponds well with the measured
                           results. The conclusion is that the MSV calculation is acceptable, the problem
                           is with its worth.
                           Another side effect of the increased squish velocity is that the convection heat
                           transfer between the gas and the piston and head is increased. This is often
                           claimed as the primary reason to use squish action to stop detonation.
                           Preliminary calculations have shown that this effect, especially in high
                           revving engines, is almost negligible.
                           4. Combustion Picture
                           To help with forming a better mind picture of the combustion process a
                           simulation was done on an YZ250U engine and the dimensions of the burnt
                           sphere of gas calculated for each time step. This, together with the piston
                           position from TDC was written to file and a series of seven pictures generated
                           from this.
                           A squish clearance of 1.2mm and a squish area ratio of 50% were used. This
                           resulted in a MSV of 28m/s at 10deg BTDC.
                           In the model the following assumptions were made:
                           • Combustion proceeds in a spherical shape. This is not far from reality
                           but without a detailed computational fluid dynamic simulation not
                           possible to predict.
                           • The ignition timing is set at 20deg BTDC. For the tested engine it was
                           19deg but as the pictures were generated at 10deg intervals this was
                           changed.
                           • The measured delay period was 9deg but this was changed to 10deg to
                           get the combustion to start at the measured position and to correspond
                           to a 10deg interval.
                           • The actual combustion period was 51deg but was changed to 50deg
                           once again to correspond to the 10degree intervals.
[TD=align: left]
The first picture shows to scale where the piston is relative to the combustion chamber at the point of ignition.
The  second picture shows the piston position at the end of the delay period  and thus the start of turbulent combustion (10deg                                        BTDC). This is also the point  where the squish velocity is at a maximum (MSV). The flame kernel is now  bigger than a turbulent                                        eddy.
The  next picture shows the piston at TDC. As can be seen the flame sphere  has grown substantially in size and is just beginning                                        to touch the piston crown. If a  plug with a protruding tip was used the flame would have touched the  piston a few degrees                                        sooner.
                                 [/TD]
                                  [TD=align: center]
At  10 degrees after TDC the hemisphere of the chamber is almost fully  enflamed and the flame front is on the point of moving                                        into the squish area. As can be  seen the squish area is rapidly opening up and will be experiencing  reverse flow
At 20deg ATDC the flame front is about halfway into the squish area and the squish clearance is quite big already. No chance                                        of the flame in the squish area getting quenched.
At 30deg ATDC the squish area is now fully enflamed and only a small part of the piston crown and of the cylinder bore is                                        not yet enflamed. At this point even the reverse squish flow is negligible.
The final picture is at 40deg ATDC and shows the piston position with the complete chamber enflamed
This is still way before the exhaust port opens which points to the fact that for burning mixture to exit the exhaust port                                        something serious has to be wrong with the combustion process.
                                 [/TD]
                               [/TR]
                            [/TABLE]
5. Summary
                           So what have we learned:
                           • As far as squish is concerned whether it helps or not depends on the
                           residual turbulence at the time of combustion.
                           • As for squish quenching the flame at the edge of the squish band to
                           stop detonation is not looking very likely.
                           This is not the final word on the subject. As I learn more I keep changing my
                           mind and I am sure it will continue to happen for a while yet. Hopefully
                           somebody reading this will be able to help me right where I am still
                           misunderstanding squish and definitely turbulence!
