Author Topic: Need some Identification help  (Read 3020 times)
Offline lrd_250r
« on: February 15, 2016, 05:10:49 PM »
Guys this durablue axle came with my atc250r project, can someone tell me if it's for a 1985 or 1986 atc250r and which model axle it is?
Sent from my SM-G900V using Tapatalk
Offline lrd_250r
« Reply #1 on: February 15, 2016, 05:11:20 PM »
Offline dp250r
« Reply #2 on: February 16, 2016, 10:09:40 AM »
My guess is it is for the 85 250r .Because the rear sprocket mounts on the outside of the hub.The 86-89 sprockets mount on the inside of the hub.The 85 rear axle will not work on the 86-89  .But the 86 and up axle will work on the 85.Im not sure on wich durablue it is.
Offline lrd_250r
« Reply #3 on: February 16, 2016, 02:00:24 PM »
Thanks. All I need is a the 1985 carrier and this thing will be a roller
Offline The_Steve_Man
« Reply #4 on: February 18, 2016, 10:58:15 AM »
Is it going on an 85? You cant put an 85 carrier in an 86 up swingarm. Too small. You might be able to get a sprocket hub from durablue for the 86 .
