Author Topic: How to measure your Cylinder Head Squish Clearance...  (Read 5587 times)
« on: July 30, 2013, 04:56:40 PM »
[h=1][SIZE=+2]How to Measure
Your Cylinder Head Squish Clearance...
[/SIZE]
[/I][/h]     The "squish"   band is a somewhat narrow angle cut into the outer periphery   of the combustion chamber that comes into a close clearance proximity   with the piston crown outer edges at TDC (Top Dead Center) of   crankshaft rotation.  Measuring it accurately so as to make   decisions about what modification(s) should be made to an engine's   compression ratio and combustion chamber is a critical reference   step in planning a high performance motor.
        To   determine your actual squish clearance...
        You   will need about a 10" length of solder of a diameter that   is thicker than your current squish clearance.  Common available   diameters are approximately .038", .065", .090"   and about .140".  Start with the .065" (in tightly   set-up race engines of smaller displacement you may need only   the .038") and if it is not thick enough because your squish   clearance turns out to be greater, just go up to the next size.
        Cut   the solder tips squarely with a single edge razor blade so each   tip is cut perfectly perpendicular to the solder length.  This   is VERY IMPORTANT to get accurate indications from the very edge   of the combustion chamber limits!  Bend the solder into   an upside down "U" shape with the "legs"   about 1/2" apart and parallel to eachother.  Now cross   the "legs" over eachother (in the shape of one of those   ever popular politically correct symbolistic ribbons that we're   instructed to wear by our fearless leader everytime we have a   national tragedy...).  You should now have an inverted "U"   of solder with "legs" crossed in an "X" pattern.
        Remove   spark plug from your engine.  Bring the engine up to approximate   top dead center (follow the piston up the bore with another piece   of solder stuck into the plug hole.......).  Now back the   motor up opposite normal direction of rotation until the piston   has dropped about an inch back down the bore.  Insert your   two "legs" of solder into the plug hole while holding   the solder by its' "U".  Push and allow the "legs"   to splay left and right across the piston dome INLINE WITH THE   WRIST PIN AXIS.  Do NOT push the "legs" fore and   aft (front to back) in the bore or the potential for the piston   to "tilt" on the wrist pin in its' cylinder wall clearance   could give you false readings.
        You'll   be able to "feel" the tips of the solder as they move   left and right out to the cylinder wall limits.  When you   feel them touch the cylinder wall, stop pushing and hold what   you've got with one hand while rotating the motor up to TDC with   the other hand by its' flywheel or similar.  If the solder   is thicker than your squish clearance you will feel resistance   as you reach TDC.  If the resistance is too great to roll   past TDC, select another length of solder of the next thinner   diameter.
        Roll   the engine through TDC and allow the piston to descend enough   down the bore to easily retract the legs of solder back out through   the plug hole.  Keep track of which tip was at which side   of the bore so you'll know which is which if there's a difference   in squish clearance from one side of the bore to the other!  Differences   in clearance from one side to the other are common and can be   caused by a "tilted" squish band in the head, "tilted"   piston crown, bent rod, cylinder bore not cut perpendicular to   the head mating surface, etc..  Noticing that there is a   problem and which direction the "tilt" is will alert   you to track down the culprit.
        Now measure the compressed tip ENDS (it is fairly common for the squish band angle in the
head and the radius on the piston crown to diverge slightly, thus your "tightest" clearance will be
right at the very ends of your solder) and record them.  This is your actual squish clearance at TDC.[SIZE=-1]
[/HR][/COLOR][/SIZE][/FONT]
Full credit for this article goes to RICHARDS' ENGINE DEVELOPMENT
you can see the original post here ---> http://www.sacoriver.net/~red/squish.html
« Reply #1 on: July 30, 2013, 05:55:36 PM »
Squish: What it is and how to       check it
       By High Output
[/HR]This is another topic I       have seen repeated inquiries about so maybe a little discussion       would be helpful to some..........       "Squish" is a relatively narrow       circumferential "strip" around the periphery of the       combustion chamber that comes in close proximity to the outer       piston edge at exact top dead center. On two strokes it is USUALLY       of consistent width while on four strokes it is quite common       for the width and symmetry to vary and it may be referred to       as "Quench". The purpose in each case is the same.........
       1) to reduce the size of the "pocket"       or deeper centered area of the combustion chamber (thus reducing       the required "flame travel" distance to consume the       trapped fuel/air charge). Reduced flame travel distance is always       a good thing as it reduces the time needed to burn the fuel/air       mixture and reduces the likelihood for the more distant gases       to be preheated and possibly spontaneously combust before the       flame gets there (detonation).
       2) to force the end gasses at the bore's       edge into the "pocket" and impart turbulence which       will promote a more homologous mixture of the fuel and air thus       reducing fuel droplet size and exposing more fuel surface area       to the upcoming spark event. This will improve the quantity of       fuel/air mixture that is combusted with less waste and more pressure       yield.
       Generally speaking, a "tighter"       squish clearance at top dead center is desirable because it reduces       the quantity of fuel/air mixture that is stored away from the       flame source. The tighter the squish, the more turbulence imparted       and the higher the velocity of the mixture as it enters the pocket.       But because you must have enough clearance to deal with slop       in the main, big end and small end rod bearings, piston to cylinder       wall clearance, piston expansion, etc. without allowing the parts       to actually touch, there are limits as to how tight the squish       clearance can be. (It also has been found that too high a value       of squish velocity can encourage the onset of detonation, too.)       This requires that a person be able to measure accurately his       or her actual squish clearance to determine how their motor rates.       It is incredibly simple to accomplish.......
       You will need about a 10" length of       solder of a diameter that is thicker than your current squish       clearance. Common available diameters are approximately .065",       .090" and about .140". Start with the .065" and       if it is not thick enough because your squish clearance turns       out to be greater, just go up to the next size. Bend the solder       into an upside down "U" shape with the "legs"       about 1/2" apart and parallel to eachother. Now cross the       "legs" over eachother (in the shape of one of those       ever popular politically correct symbolistic ribbons that we're       instructed to wear by our fearless leader evrytime we have a       national tragedy........ whoops! sorry! I'll stop the political       innuendo....). You should now have an inverted "U"       of solder with "legs" crossed in an "X" pattern.       Remove spark plug from your engine. Bring the engine up to top       dead center (follow the piston up the bore with another piece       of solder stuck into the plug hole....... if it's a four stroke,       make sure both valves are closed as you approach TDC. If not       rotate the motor through another 360ΓΈ and they will be).       Now back the motor up opposite normal direction of rotation until       the piston has dropped about an inch back down the bore. Insert       your two "legs" of solder into the plug hole while       holding the solder by its' "U". Push the "legs"       left and right across the piston dome INLINE WITH THE WRIST PIN       AXIS. Do not push the "legs" fore and aft (front to       back) in the bore or the potential for the piston to "tilt"       on the wrist pin in its' cylinder wall clearance could give you       false readings. You'll be able to "feel" the tips of       the solder as they move left and right out to the cylinder wall       limits. When you feel them touch the cylinder wall, stop pushing       and hold what you've got with one hand while rotating the motor       up to TDC with the other hand. If the solder is thicker than       your squish clearance you will feel resistance as you reach TDC.       Roll the engine through TDC and allow the piston to descend enough       down the bore to easily retract the legs of solder back out the       plug hole. Keep track of which tip was at which side of the bore       so you'll know which is which if there's a difference in squish       clearance from one side of the bore to the other. Differences       in clearance from one side to the other are common and can be       caused by a "tilted" squish band in the head, "tilted"       piston crown, etc.. Now measure the compressed tips of the solder       and record them. This is your actual squish clearance at TDC.
       Optimum squish clearance is decided by       squish angle vs. piston crown radius(and how close they are to       paralleling eachother), squish width and area as a percentage       of bore area, cylinder bore size, piston manufactured style (cast       or forged, which dictates expansion and required piston to cylinder       wall clearance), uncorrected compression ratio and most importantly       dynamometer testing. These are all subjects that will require       addressing on another day. Hope this helped and made some sense.       Have a great day!
