Author Topic: WTB- 89 TRX engine mounts  (Read 4555 times)
Offline mudbogger
« on: March 13, 2016, 09:39:05 AM »
Looking for a set of used engine mounts for a 89 trx 250r, with bolts and nuts would be great, but not necessary, can do any form of payment to seller. Thanks!
« Last Edit: March 19, 2016, 08:36:33 PM by mudbogger »
« Reply #1 on: March 13, 2016, 04:31:22 PM »
Quote from: mudbogger;65373
Front engine mounts are interchangeable for all years trx 86-89
Offline mudbogger
« Reply #2 on: March 13, 2016, 04:44:47 PM »
Great thanks. For some reason I am missing the front 2 mounts, but found them today on eBay.
I have a question, your gusset kit the very bottom engine mounting bolt I have does not fit since installing your new frame brackets, mine is too short, is perhaps mine the wrong bolt or does your gusset kit require new bolts?
Offline mudbogger
« Reply #3 on: March 13, 2016, 04:49:34 PM »
Ok great thanks. I am missing the 2 fronts but found them on eBay today.
Does your gusset kit require any new bolts or nuts by chance? I have one on the lowest mount under the engine that is too short. Since everything on this ride was or is incorrect I am leaning toward a wrong length bolt but wanted to ask.
« Reply #4 on: March 13, 2016, 05:44:24 PM »
I have a few sets of front mounts if you want a set for the cost of shipping. Or Pumashine makes nice stainless mounts for a good price.
« Reply #5 on: March 13, 2016, 05:49:24 PM »
Quote from: mudbogger;65396
The gusset kit has replacement lower motor mounts. The 87-89 style would have to be bent after welding to hold the motor like OEM. If you have any problems take a pic and post it up here. Were all here to help.
Offline mudbogger
« Reply #6 on: March 13, 2016, 07:44:15 PM »
Thank you sir, can I perhaps buy the bolts and nuts from you with them if possible?
Offline mudbogger
« Reply #7 on: March 13, 2016, 07:45:51 PM »
I had them welded in next to the original mounts, I did not understand that the old mounts are to be removed? Guess thats why my bolts do not fit lol. I will take a picture here and post it. Thanks for the help, the gusset kit really helped out big time!
Offline mudbogger
« Reply #8 on: March 13, 2016, 08:39:54 PM »
Quote from: Pumashine;65400
here is a picture of the mounts, was I supposed to remove and or bend the factory mount over?
« Reply #9 on: March 13, 2016, 08:44:14 PM »
Quote from: mudbogger;65408
The replacement motor mounts are not gussets. If you put them on the outside you may be able to run a longer bolt. If welded on the inside the motor will not fit. One of the motor mount bolts are  a hair longer. I have them If you need one.Part# 96400-1014000
Offline mudbogger
« Reply #10 on: March 13, 2016, 09:17:36 PM »
Yes please I can use it. I did weld them on the outside, the engine fits in the frame right now. Can I purchase it on your site by chance? Thanks for the help!
« Reply #11 on: March 15, 2016, 05:20:58 AM »
Just FYI on there are pictures on the gussets installed on the website where you ordered them.
Offline mudbogger
« Reply #12 on: March 15, 2016, 08:02:24 PM »
Quote from: Hawaiiysr;65487
thanks. i will leave as is a use a longer bolt.
