Author Topic: Newbie 1989 trx 250r project  (Read 16961 times)
Offline mudbogger
« Reply #15 on: April 09, 2016, 08:07:59 PM »
yeah, I have dealt with them in the past but the space needed to get the carb all the way into the intake is way too much-I do have a alumn BOX that I picked up off Ebay from CDR? performance but what intake do you use for it? The stock is not going to work on that box-
« Reply #16 on: April 09, 2016, 08:41:01 PM »
That i do not know. Maybe another member will have a answer  for ya.
« Reply #17 on: April 09, 2016, 09:56:06 PM »
With all the oem intake components & airbox mounted there's a 1" gap? Got pics?
Offline mudbogger
« Reply #18 on: April 10, 2016, 08:22:28 AM »
Yeah I got it on the carb without using a spacer but then you can't get it into the rubber grommet because it is too far in, hence the question about the spacer.
I was also looking to see what was being used with the aftermarket alumn box in regards from the carb to box inlet. Is it from a 3 wheeler?
Offline mudbogger
« Reply #19 on: April 10, 2016, 08:23:51 AM »
Yes I will take a pic and post. Again the ride is in my unheated garage so the rubber is not flexible at all but the gap seems way too much.
« Reply #20 on: April 10, 2016, 08:51:12 AM »
3 wheeler air box is totally  different stock vs stock. I would  think the same  when aftermarket
Offline mudbogger
« Reply #21 on: April 10, 2016, 12:07:55 PM »
Pic. This is without the rubber grommet installed for the air box in the frame.
« Reply #22 on: April 10, 2016, 01:09:29 PM »
The reed spacer  will take care of that.
Offline mudbogger
« Reply #23 on: April 10, 2016, 04:33:33 PM »
Thanks for the help
« Reply #24 on: April 11, 2016, 12:10:48 AM »
If you are wanting a rad valve. I have one that doesn't have the reeds. I would give ya a deal
Offline mudbogger
« Reply #25 on: April 11, 2016, 06:31:18 AM »
Thanks I have a valve already ready for install. My problem with that is the stock carb is way to small for it, hence the question about aftermarket carbs.
« Reply #26 on: April 11, 2016, 01:23:19 PM »
I think they made different size boots. Trx has a smaller carb stock than cr250. Mine was marked for the smaller carb. I can take pic for you
Offline StrokedAZ
« Reply #27 on: April 12, 2016, 01:08:27 AM »
If I remember the cr250 rad valve was designed for a 38mm carb whereas the trx250r rad valve was made for the 35mm carb.  You probably have the cr version. I have a rad valve for the trx (i think it had a 04 stamped on the side) and it fits perfect.
Sent from my Galaxy S5
86 TRX 250R
« Reply #28 on: April 12, 2016, 02:17:26 AM »
I have the CR & TRX rad valves & the valve inlets & boots were all the same & fit the bigger carbs. Boyesen might make a boot to work with the stock 34mm carb but I think 36mm is where the larger Keihin throats start & those are the standard boots on rad valves. If Boyesen doesn't make an adapter for the rad valve to stock carb you could make your own pretty easy.
Offline mudbogger
« Reply #29 on: April 24, 2016, 08:47:42 PM »
Thanks for the help, I spoke to a Boyesen rep and they indeed do make a valve for the 34mm stock carb, which is what I will order. I have the rad valve here and the spacer did indeed take all the space out.
