Author Topic: Sprocket hub snap ring  (Read 3011 times)
Offline PNWrider
« on: March 23, 2016, 12:18:46 PM »
So I got my new durablue hub on but can't get the snap ring back in place. Is there an easier way than trying to use snap ring pliers that keep slipping?
« Reply #1 on: March 23, 2016, 01:02:41 PM »
Did you try a piece of pipe ? You are talking about the Sprocket Hub retaining ring ? Tap it on and into place with a piece of 1-1/2" SCH40 pipe....(1.610"ID)
I did this a few weeks ago....but couldn't find the piece of pipe I used.....it was a piece of cake to install with the pipe.....a real BITCH without!
« Reply #2 on: March 23, 2016, 01:03:58 PM »
tap it around with a flat piece of steel , or find a pipe with right diameter.
« Reply #3 on: March 23, 2016, 10:46:49 PM »
Quote from: Langbolt;65849
This is the best method imo. You can even take it a step farther & cut a thin piece of aluminum pipe to go between the steel pipe & hub to reduce the chance of marring the face of the hub.
Offline dem3500
« Reply #4 on: March 24, 2016, 01:11:36 PM »
i always just push it on by hand or 2 flat head screw drivers. never had any sort of problem lol
Offline PNWrider
« Reply #5 on: March 24, 2016, 02:39:15 PM »
Going to try the pipe trick, been using the screw drivers but no luck
« Reply #6 on: March 24, 2016, 04:13:38 PM »
Quote from: PNWrider;65900
Two hammer handles work great as well with a wider push area.
Offline PNWrider
« Reply #7 on: March 24, 2016, 07:10:26 PM »
Thanks for the info guys! Just got home and got it on in one try with a 1 1/2" pipe!
« Reply #8 on: March 24, 2016, 07:46:16 PM »
Glad it worked.  My snap ring is not recessed like yours into the hub
