Author Topic: Afco fittings  (Read 3444 times)
Offline sangheraent
Afco fittings
« on: April 08, 2016, 11:11:25 PM »
I know I know I posted about buying a CBR radiator but I have been doing some research and it seems like afco is a bit more popular, I was wondering if anyone knows which fittings I will need to run an afco if I decide to go that route? I have to order it online and pick it up on my way to oregon so I cant just take it to an auto parts store I have to have the fittings before hand. I found the link for the rad hoses.
Offline Fear250r
Afco fittings
« Reply #1 on: June 20, 2016, 01:59:14 AM »
Mine came with all the fittings. Are you sure it doesn't come with them?
In house hybrid ball buster
Offline Uns
Afco fittings
« Reply #2 on: June 20, 2016, 12:22:47 PM »
Quote from: sangheraent;66428
Mine didn't come with fittings a few years back.   You basically need to go from 1/2" npt male to 1/2"/-12an hose barb fitting.  A fancy way to do this would be:
https://www.summitracing.com/parts/SUM-220246/
into
https://www.summitracing.com/parts/AER-FBM1525/
There are tons of options, including different curves for the hose barb fitting depending.  I needed a 90 and a 45 degree for my setup(you wont be able to use the stock lower hose.)  You could save a bunch of money and just go:
https://www.summitracing.com/parts/der-15712/overview/
That straight and simple one above says aluminum(which I would definitely stick to similar metals), but looks brass?  For the price, could try them out, or go to a local specialty hose shop.
and I used some of this for the threads:
https://www.amazon.com/Permatex-80632-Thread-Sealant-PTFE/dp/B000HBNTGY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1466438833&sr=8-1-fkmr0&keywords=pipe+sealant+npt+permatex
I like the "fancier" setup because I can change directions on the fittings by replacing the -12an to hose barb fitting, and they also rotate 360.  I'd not want to have to disassemble the NPT fitting, the threads are pretty much crap.
"Valvetrains? Where we\'re going, we don\'t need Valvetrains." - Me
