Author Topic: Billet bowl Pwk carb  (Read 3693 times)
Offline Morse250r
« on: April 17, 2016, 09:05:55 PM »
Bought from a member on here. I opened and then put it on the shelf.  One corner is ground a bit I'm guessing for clearance on the case.  60 shipped very nice
88 rb racing duner
Trx 70\'s
Atc 125
Offline fast350r
« Reply #1 on: April 18, 2016, 01:24:12 AM »
Does it have the cap at the bottom
Shearer 431 puma
Offline Morse250r
« Reply #2 on: April 18, 2016, 05:20:50 AM »
No as pictured. Remove it from the stock bowl looks like
88 rb racing duner
Trx 70\'s
Atc 125
Offline Aceman
« Reply #3 on: April 18, 2016, 09:13:37 PM »
I'm staring at it trying to figure out how it even bolts up?  I see the inner 4 holes next to the bowl o-ring, those are the original bowl holes that line up with the carb, right?  But they're recessed inside this bowl where you can't put screws through them?  What am I missing?  Are you supposed to run screws through the outside holes into what?
Arens Axis XC 310R
Houser Axis Duner CT350PV
« Reply #4 on: April 18, 2016, 10:07:39 PM »
Quote from: Aceman;66718
kind of hard to tell in the pics, but it is a 2 piece bowl. you attach the top half of the bowl to the carb first with the stock location screws to the carb body, then the bottom half of the bowl attaches to that with the outer 4 screws.
Offline Morse250r
« Reply #5 on: April 19, 2016, 11:07:43 AM »
^^ exactly right the inner holes you put the screws from your existing bowl in then you bolt the billet bowl up to that plate
88 rb racing duner
Trx 70\'s
Atc 125
« Reply #6 on: April 20, 2016, 10:01:04 AM »
Does it use the same type seal as the bowl? I'm just wondering about replacement.
Offline Morse250r
« Reply #7 on: April 20, 2016, 09:00:33 PM »
Sold
88 rb racing duner
Trx 70\'s
Atc 125
