Author Topic: 87 trx250r + ESR 330 motor  (Read 4650 times)
Offline fastford406
« on: April 18, 2016, 10:50:34 AM »
 This is a beautiful 87 trx250r that I have built over the past 3 years. I have ran a half a tank of fuel through it since completion. Front shocks have been rebuilt by Works, 400ex spindle and brake conversion. The wheels are the originals so they have some scratches and small dings that have been powder coated over. Many other new parts. The motor in the bike now is fresh from top to bottom Wiseco piston and rod, only .5mm over stock bore. I built this motor to be reliable it is all stock except for v force reeds, 36mm air striker carb and CT mid pipe. If you feel the need for speed included is a 330 ESR motor with TRX 9 porting and an FTZ in frame drag pipe. This motor runs on premium pump gas it also has a fresh top end. I am unsure on the size of carb on it. It does have CR250 ignition that could use a little work but, everything is there and it worked when I pulled it out. $5000 obo for everything Call/Text for details additional pics or video 8one6-nine7seven-6eight9zero.
 ·         Protaper fat bars
 ·         New Gripper seat cover
 ·         +2 +1 A arms
 ·         Rebuilt Works shocks
 ·         Shock wears
 ·         CT mid pipe and silencer
 ·         New Dunlop quadcross tires 20x7x10 and 18x10x9
 ·         36mm PWK Air Striker Carb
 ·         V force reeds
 ·         Air box eliminator with UNI filter
 ·         Durablue axle
 ·         07 400ex spindle hubs and brakes up front
 ·         06 CRF 450 caliper on the rear
 ·         Lots of powder coat
 ·         330 ESR motor
 ·         TRX9 porting
 ·         Fresh top end
 ·         Big bore Keihn carb
 ·         FTZ head pipe
 ·         CR250 ignition
 ·         Cool Head
« Reply #1 on: April 18, 2016, 12:00:14 PM »
great looking bike. could u elaborate on this a little more?
Quote from: fastford406;66698
Offline fastford406
« Reply #2 on: April 18, 2016, 12:05:43 PM »
Whoever put the CR ignition on the 330 before spliced the 250r and cr wire harness together and didn't do a very good job of it. I have a factory 250r harness I would throw in so someone could make it look a lot better. I mean everything is there and it worked I just think it could be done better is all.
« Reply #3 on: April 18, 2016, 12:29:35 PM »
is that a weisco rod or crank?
Offline fastford406
« Reply #4 on: April 18, 2016, 12:47:07 PM »
Its the rod and piston. Its still the factory crank.
