Author Topic: Brake stay fitment  (Read 8148 times)
Offline swanitalia
Brake stay fitment
« on: April 25, 2016, 08:50:19 AM »
Hello everyone, I was getting my quad all put together this past  weekend. When I went to install my rear brake caliper on my new billet  brake stay, the holes would not align correctly kinda like the brake  stay was cut short.
I have a laeger swing arm with a billet  carrier and a RPM axle and anti-fade. The axle and anti-fade, and billet  brake stay are new parts for this build. Before I swapped the axle the  brake was on the OEM stay without a problem.
What should I do for  this problem? Try to get the caliper on the stay or should I put the  OEM stay back on and see if the problem still exists?
This stopped me from riding this weekend so I want to get it worked out ASAP so I can finally ride.
Any help would be great.
Offline Langbolt
Brake stay fitment
« Reply #1 on: April 25, 2016, 03:59:37 PM »
Stock bolt spacing is 4-1/2" center to center ? What are you gettting ? If it's 4" it might be set up for a CRF Front Caliper swap. :)
Offline swanitalia
Brake stay fitment
« Reply #2 on: April 25, 2016, 04:12:04 PM »
Quote from: Langbolt;66918
The spacing is 4-1/2" a member suggested that i have the carrier in the wrong position so I am going to try turning that to see if that is the problem.
Brake stay fitment
« Reply #3 on: April 25, 2016, 05:11:25 PM »
Quote from: swanitalia;66919
What kind of carrier are you using I have had this issue with the bearings being wider.
Offline ccaiazza
Brake stay fitment
« Reply #4 on: April 26, 2016, 08:35:51 AM »
Just rotate the carrier
Offline swanitalia
Brake stay fitment
« Reply #5 on: April 26, 2016, 08:42:15 AM »
Quote from: Skeans1;66920
It's a LSR billet carrier.
Offline swanitalia
Brake stay fitment
« Reply #6 on: April 26, 2016, 08:43:04 AM »
Quote from: ccaiazza;66941
I will be doing that today or tomorrow depending if I get off work early.
Brake stay fitment
« Reply #7 on: April 26, 2016, 09:14:41 AM »
Quote from: swanitalia;66944
Take your stock brake stay and make sure your new billet one is the exact same, it's possible a batch of bad stays was made.
Offline swanitalia
Brake stay fitment
« Reply #8 on: April 26, 2016, 10:30:31 AM »
Quote from: Skeans1;66946
If rotating the carrier doesn't work i am planning on taking the billet stay off and comparing it to the OEM stay.
Brake stay fitment
« Reply #9 on: April 26, 2016, 10:31:38 AM »
Quote from: swanitalia;66948
I don't think you'd need to pull it I'd just put the oem up against the billet one.
Offline swanitalia
Brake stay fitment
« Reply #10 on: April 26, 2016, 10:42:41 AM »
Quote from: Skeans1;66949
I will have to take a look, the anti-fade gets in the way slightly.
Brake stay fitment
« Reply #11 on: April 26, 2016, 06:34:01 PM »
As said before the carrier is probably just turned too far. If the carrier is rotated too far the caliper hits the top of the carrier housing on the swinger. Thats why honda puts a stop on the OEM carrier.
Brake stay fitment
« Reply #12 on: April 26, 2016, 07:15:01 PM »
where is the brake stay from; what kind?
Offline swanitalia
Brake stay fitment
« Reply #13 on: April 27, 2016, 08:09:20 AM »
Okay I think i solved the problem, it appears that I over rotated the bearing carrier and had to turn it back quite a bit. But the brake caliper lines up now, thanks for the help everyone!
