Author Topic: Quadcross NW Albany, OR Round 2 5/21-22  (Read 20556 times)
Offline PNWrider
« Reply #15 on: May 25, 2016, 02:54:02 PM »
Thanks for the input guys I will definitely be airing down the tires a bit in the future. As far as the clutch goes, this is the 2nd race I've done ever but probably 50 hours of dune riding on it, last I checked the fibers looked fine
« Reply #16 on: May 25, 2016, 03:15:09 PM »
Quote from: PNWrider;67785
I would think the clutch is probably ok, especially with the set up you are using. I think using stronger springs makes a big difference in how long it lasts. My Barnett kevlar clutch fibers have lasted a very long time.
Offline zcarlson12
« Reply #17 on: May 26, 2016, 08:58:46 AM »
Ya clutch should be fine. I put 30-40 motos on my last oem clutch and it was still well within spec but I replaced it for a spare. Mess around with tire pressure during practice and let us know what you find out.
« Reply #18 on: May 26, 2016, 09:14:46 AM »
Y'all would drop your jaws if I told you that my clutch has been in there since 2001. I was gonna replace it, but the clutch fibers looks just about as good as new ones.
« Reply #19 on: May 26, 2016, 03:22:55 PM »
Your not using your clutch enough if its that old.  You could be faster with more clutch use.
Offline PNWrider
« Reply #20 on: May 26, 2016, 08:27:47 PM »
Quote from: Burns363R;67809
Like feathering the clutch to keep the rpms up? I used it all the time in the dunes but not as much on the tracks yet.
« Reply #21 on: May 26, 2016, 09:20:59 PM »
Quote from: PNWrider;67815
That'd be my good guess, Bryan what motor and setup are you running?
Offline PNWrider
« Reply #22 on: May 26, 2016, 09:34:49 PM »
Quote from: Skeans1;67818
ESR 300 Cylinder LED porting, Lrd team b pipe, 38AS carb, cr ignition, oem clutch fibers with 400ex plate and cr500 springs with extra washer. Stock gusseted 88 frame, elka stage 3 long travel fronts and standard rear rebuilt at SFRacing
« Last Edit: May 26, 2016, 09:38:52 PM by PNWrider »
« Reply #23 on: May 26, 2016, 09:38:57 PM »
Quote from: PNWrider;67819
ESR 300 Cylinder LED porting, Lrd team building pipe, 38AS carb, cr ignition, or oem clutch with 400ex plate and cr500 springs with extra washer. Stock gusseted 88 frame, elka stage 3 long travel fronts and standard rear rebuilt at SFRacing
If you want get a hold of me you can try a larger bore motor that's a tractor.
Offline PNWrider
« Reply #24 on: May 26, 2016, 09:51:57 PM »
Haha how big is it Jared? And how much?
« Reply #25 on: May 26, 2016, 10:13:44 PM »
Quote from: PNWrider;67821
431 I'm not selling but it'd give you an idea of the difference in torque.
Offline PNWrider
« Reply #26 on: May 26, 2016, 11:08:28 PM »
Quote from: Skeans1;67822
Haha damn that's big. Eventually I'll up my motor but working more on technique and physical shape right now. I couldn't imagine racing an xc race anytime soon like Kyle does lol
« Reply #27 on: May 26, 2016, 11:12:24 PM »
Quote from: PNWrider;67825
Lol endurance is the big thing then technique and last motor. Good endurance work is being out on the brush cutting all day.
« Reply #28 on: May 27, 2016, 06:59:30 AM »
Sorry, i was referring to Ryans post.  XC you dont need to feather the clutch at all really.  Clutchs would last alot longer in XC.  For MX you will want to feather the clutch more the faster you get.  No matter how much tq our motors make, it wont be as good as a four stroke.  And that being said Top 4 stroke riders have to replace there clutch ever few races to give you an idea how hard they are on them.  My point was that if you have the same clutch for several years of racing, your leaving alot of time on the table at the track.
« Reply #29 on: May 27, 2016, 09:37:21 PM »
Quote from: Burns363R;67831
So kyle a 50 ft lbs puma as cast won't keep up on a 4 stroke I have both and you're welcome to come prove me wrong. Till I see it I'll believe it from your video you need to learn to learn to ride in timber as well as use the full bike.
