Author Topic: New ESR motor running great  (Read 9160 times)
Offline huntertools
« on: June 17, 2016, 08:00:42 PM »
Just got my new motor in and live it.
New 310 ESR cylinder ported by Neil (thanks Neil)
New ESR cases, clutch cover, stator cover
New Hot Rod crank and seals and bearings.
Started out jetting fat with all new electrical except CDI that was my spare Ricks cdi
. Motor started up second kick and sounded good. Did about three heat cycles then rode around the yard maybe quarter throttle for five minutes. Was running a little hot so checked everything and found no problems. Made several more runs like this and was still too hot for my liking 200F. Didn't feel like it had as much bottom end power but I blamed this on the jetting. Got a OEM cdi and it made a huge difference. Temp dropped to 180 and pulls hard with plenty of bottom end power. Almost like a four stroke. Sure I will be going up on my gearing soon.
Thanks again Neil for an awesome port job. Better than I expected.
« Last Edit: June 17, 2016, 08:32:46 PM by huntertools »
Offline StrokedAZ
« Reply #1 on: June 17, 2016, 08:40:19 PM »
That looks sweet.  Have fun ripping it
Sent from my Galaxy S5
86 TRX 250R
« Reply #2 on: June 18, 2016, 12:17:29 AM »
Good to hear it's running well!  Love how the ESR stator cover has recessed bolt holes.  How does that stick-on temp gauge work?
Offline huntertools
« Reply #3 on: June 18, 2016, 12:25:17 AM »
When cold all black. As area heats up each progression turns green to yellow. Easy to read
« Reply #4 on: June 18, 2016, 06:58:40 AM »
Do you have an in-line water temp gauge?
John
Offline huntertools
« Reply #5 on: June 18, 2016, 08:49:23 AM »
Quote from: jcs003;68282
John
Just have a stick on temp sticker. I know it's not dead on but it gets me in the ball park. Used them on several applications and they seem to be close.
Offline jfwyatt1
« Reply #6 on: June 18, 2016, 03:41:31 PM »
i see about a 20-30 degree varience between my tape guage and the inline temp gauge. tape being higher.  looks real nice my son and i love our 310.
Offline mwiley
« Reply #7 on: June 18, 2016, 09:11:12 PM »
I am looking at doing almost the exact same build but maybe a little larger cc. Can you give us a round about cost for everything with the cases, crank and any extras. About how long did all the work take to get done? If you don't want to say publicly, can you just PM me.
Thanks,
Mike
Offline huntertools
« Reply #8 on: June 18, 2016, 11:22:04 PM »
Quote from: mwiley;68295
Thanks,
Mike
PM sent.
« Reply #9 on: June 19, 2016, 07:42:19 AM »
Very nice. Enjoy.
« Reply #10 on: June 20, 2016, 07:54:45 AM »
The motor looks sharp. Glad you are enjoying. Yep, the ESR 310 is the best bang for the buck when it comes to bumping up the power over stock. Great platform to build off of.
« Reply #11 on: June 20, 2016, 10:22:21 AM »
That does look very good. Very clean but bold look.
Offline Sand_Blaster
« Reply #12 on: June 21, 2016, 03:36:03 PM »
Very nice motor. So happy eddies cases have no issues, & we can keep our 250rs going even when Honda refuses to keep making parts.
87 Trx250r & 99 Banshee
Offline 86 4trax
« Reply #13 on: July 07, 2016, 02:16:18 AM »
Not to derail the thread, but I recently came across ESR cases and I was wondering if the ESR standard cases were compatible with all OEM Honda parts.If not,is there any alternative other than used OEM?
Offline huntertools
« Reply #14 on: July 07, 2016, 05:07:36 AM »
All transmission, clutch side components and counter balancer are OEM parts. Crank is a Hot Rods. Cylinder, clutch cover and stator cover are ESR but OEM will bolt right up. No issues what so ever putting this motor together. Would highly recommend to anyone needing cases.
