Author Topic: New ESR motor running great  (Read 9235 times)
Offline 86 4trax
« Reply #15 on: July 07, 2016, 06:00:14 AM »
Quote from: huntertools;68595
All transmission, clutch side components and counter balancer are OEM parts. Crank is a Hot Rods. Cylinder, clutch cover and stator cover are ESR but OEM will bolt right up. No issues what so ever putting this motor together. Would highly recommend to anyone needing cases.
Much appreciated.
« Reply #16 on: July 07, 2016, 10:08:45 AM »
Quote from: 86 4trax;68591
Not to derail the thread, but I recently came across ESR cases and I was wondering if the ESR standard cases were compatible with all OEM Honda parts.If not,is there any alternative other than used OEM?
The only difference between the OEM Honda cases & the ESR cases, you'll have to use both ESR case halfs to build the engine, because they will not match up to a used OEM TRX250R case half.
Machining to the center of the ESR cases is a bit different & they wont match up to the OEM case halfs.
Really though that is a good thing, because you'll have all brand new cases to build with & you'll see they are beefed up in areas where the OEMs were prone to crack.
