Author Topic: High idle still.  (Read 6933 times)
Offline yugyagz
High idle still.
« on: July 07, 2016, 06:42:53 PM »
I have a 39mm keihin. It has 170 main. 600 feet above sea level. Was missing idle adjusting screw so I purchased one and it still idles super high when I start quad. Doesn't matter where I have idle adjuster. Same idle. I've cleaned carb. Reset air screw. Seems that when I put I'm gear it drops down. After I run a bit it settles. Any help?
Sent from my VS985 4G using Tapatalk
Offline yugyagz
High idle still.
« Reply #1 on: July 07, 2016, 06:45:17 PM »
Needle is middle clip forgot that. I just don't know what else to check. Maybe not even carb issue? I haven't done a leak down and know I need to.
High idle still.
« Reply #2 on: July 07, 2016, 08:29:28 PM »
Is the cable adjusted so the slide sits as low as it can in the carb ?
Offline yugyagz
High idle still.
« Reply #3 on: July 07, 2016, 08:57:13 PM »
I do not know. But will check. Thank you. How do I adjust it?
Offline yugyagz
High idle still.
« Reply #4 on: July 07, 2016, 09:01:17 PM »
Just adjusting the cable itself by the thumb
High idle still.
« Reply #5 on: July 07, 2016, 10:28:29 PM »
Yep . Adjust it so there is a lil slack in the cable. An adjust the idle screw out .then start over adjusting the idle
High idle still.
« Reply #6 on: July 08, 2016, 12:16:03 AM »
Your PWK probably has an adjuster in the top of the cap as well.
High idle still.
« Reply #7 on: July 08, 2016, 02:14:44 AM »
Possible reasons for high idle. Air leak, improperly adjusted cable, too small of pilot jet
Offline yugyagz
High idle still.
« Reply #8 on: July 08, 2016, 05:18:55 AM »
Are you guys talking air leak on carb itself?
High idle still.
« Reply #9 on: July 08, 2016, 10:17:36 AM »
Quote from: yugyagz;68633
Nope the motor
Offline yugyagz
High idle still.
« Reply #10 on: July 08, 2016, 10:26:09 AM »
Okay so I'll do leak down test and go from there
Offline The_Steve_Man
High idle still.
« Reply #11 on: July 08, 2016, 11:04:45 AM »
You can turn your air screw out to see if the idle goes down. If it does, then your pilot is too small.
High idle still.
« Reply #12 on: July 09, 2016, 05:14:44 PM »
Quote from: The_Steve_Man;68644
Just the opposite , turning out allows for more air , you would be correct on a four stroke carb .
High idle still.
« Reply #13 on: July 09, 2016, 11:28:16 PM »
Quote from: fearlessfred;68678
Oops. You are correct. I knew what I meant but wrote it bassackwards.
Offline yugyagz
High idle still.
« Reply #14 on: July 09, 2016, 11:32:18 PM »
So I adjusted throttle cable and helped a ton. Then it seemed that when I adjusted my air screw more towards closing it was a low idle. Then it shot up like crazy fast so I shut off and moved back to wherec it was. Think I'm good now. Still trying leak down test. The plug I bought won't stopped leaking in my exhaust. Gonna try a different one tomorrow
