Workshop
Engine and Bottom End
Front sprocket
Topic: Front sprocket (Read 3423 times)
bcm
Front sprocket
July 15, 2016, 01:04:19 AM »
I was just changing out my front sprocket from a 13 to a 14 and now it looks like the chain is really close to my ESR case saver, the case saver does look like it has a chain roller down the middle does this look ok doesn't seam as I have any drag. Thanks for any help, just trying to get the 250r ready for pismo
Rupp250
Front sprocket
July 15, 2016, 02:44:53 AM »
Looks good to me. As long as it is not hitting or dragging your good to go.
DUNER -86 250R Flinstone
bcm
Front sprocket
July 15, 2016, 07:30:02 AM »
It's touches the middle section of the case saver to the middle section of the chain, the case saver looks like it has a raised ridge in the middle for the chain though, if that makes sense
dem3500
Front sprocket
July 15, 2016, 09:24:51 AM »
personally i wouldnt worry about it. if its only rubbing slightly it will clearance itself.
bcm
Front sprocket
July 15, 2016, 09:42:06 AM »
Ok thanks
Workshop
Front sprocket
