Author Topic: Transmission Problem  (Read 2866 times)
Offline Bharris
« on: July 25, 2016, 11:35:33 AM »
How much backlash should there be between gears?
I have my engine on my bench, inspecting the bottom while the top is away to be ported.  Seems that I have too much backlash between the gears.  I noticed that the shifter became very hard to snap into gear just before removing the engine.  I haven't split the cases yet to check out what's going on in the shifting mechanism, but in the meantime I have realized that have about 1/8 rotation of backlash at the Counter Shaft (or where the small sprocket was).
Thanks in advance for your help.
« Last Edit: July 25, 2016, 02:46:59 PM by Bharris »
Offline huntertools
« Reply #1 on: July 25, 2016, 08:57:17 PM »
Just checked two motors and they had about 3/4 to 1 inch of play in the transmission. Seemed normal to me. Hope this helps.
Allen
« Reply #2 on: July 26, 2016, 09:54:00 AM »
I just assembled my bottom-end. Will check this when I get home from work tonight
Offline Bharris
« Reply #3 on: July 26, 2016, 11:20:52 AM »
Thanks Tbone.  I had another buddy check last night and he has this amount of free movement on the Counter Shaft as well.
I have questions about the transmission too (this is my first time opening the case).  If you have some advice for me regarding the tranny then I sure would appreciate it.  I have the case split now, but I haven't pulled any gears out because I don't know what to look for.  While riding, my shifter was getting stuck just before engaging the next gear.  It would go into gear, but I had to put way too much upward force to do it.  Same with all of the other gears, but it seemed to get a bit easier with each gear progression.
