Author Topic: Brake piston fiber insert  (Read 12213 times)
Offline PNWrider
« on: July 29, 2016, 02:27:35 AM »
I'm rebuilding my rear brakes and need new Pistons and fiber inserts. Do these come in the new Pistons from service Honda? It doesn't show them on the microfiche. If not where do I find them, I've googled everywhere and found nothing. Not trying to run a coin in there as an alternative.
« Reply #1 on: July 30, 2016, 01:31:04 AM »
PNWrider, rear brake pistons (#'s 43107-HA2-016 and 43108-HA2-016) are discontinued.  now if you can find some NOS pistons they may or may not have the fiber end.  all depends how old they are.  Honda eliminated the fiber on the newer stock.  these were taken out of the package....
« Reply #2 on: July 30, 2016, 01:32:41 AM »
something to think about....go with a complete TRX450R setup.
« Reply #3 on: July 30, 2016, 10:10:26 AM »
this is interesting....I opened up a NOS rear caliper assembly (out of the box): no fibers.
Offline Big_Mike
« Reply #4 on: July 30, 2016, 01:53:12 PM »
Also consider a caliper rebuild kit, worked perfect for my original calipers!
« Reply #5 on: July 30, 2016, 03:49:34 PM »
Quote from: Big_Mike;69031
The fiber piston inserts don't come in the caliper rebuild kits.
Offline Big_Mike
« Reply #6 on: July 30, 2016, 04:09:09 PM »
No they do not, but he doesnt want to use a coin, so in lieu of not using a coin and not having access to fibers any more, the rebuild kit is a viable alternative..
Offline PNWrider
« Reply #7 on: July 31, 2016, 12:24:15 PM »
Damn I just noticed they're not making these anymore. Not sure how I missed that, looks like I might have to look into other options. Thanks for the input guys.
« Reply #8 on: September 27, 2016, 04:07:33 AM »
« Reply #9 on: September 27, 2016, 05:22:50 PM »
Quote from: Hawaiiysr;69778
http://www.shindypro.com/caliper_pistons.html
I hope this helps
Nice find Josh!
« Reply #10 on: September 29, 2016, 07:31:05 PM »
I try to contribute:)
Re: Brake piston fiber insert
« Reply #11 on: January 03, 2020, 10:36:22 PM »
I hope this helps
No Trx250r pistons in the list. I can’t find rear caliper pistons.  If I recall they were on EBay...not anymore. Anyone have info on where to get them
Thanks
Offline 4WHLr
« Reply #12 on: January 03, 2020, 11:37:58 PM »
Hey Joe I bought a couple sets of  those a few years ago on ebay. The seller was   cyclesrus-greatparts   and has a shop down by chippewa lake, CyclesRus if you want to go direct. Maybe he can still get some.
Bill
1986 TRX275R PC2000
« Reply #13 on: January 03, 2020, 11:53:32 PM »
Bill
Thanks Bill, I’ll contact them tomorrow (I might even stop in since I’ll be close to the shop).
« Reply #14 on: January 04, 2020, 01:53:14 PM »
These inserts could be easily made using a hole saw without a pilot bit in a drill press. Find a sheet of phenolic or a fiber material similar to the oem discs of the same thickness & make a lifetime supply.
