Author Topic: Gasket sealer  (Read 3276 times)
Gasket sealer
« on: August 01, 2013, 10:56:00 AM »
What do you guys use for gasket sealer? I used YamaBond on my center-case gasket, but its way way too sticky and doesn't spread easily at all, dam near close to dry by the time I scrambled to put it together.
Gasket sealer
« Reply #1 on: August 01, 2013, 11:19:47 AM »
Threebond 1211.
Gasket sealer
« Reply #2 on: August 01, 2013, 11:24:20 AM »
Which number yamabond are you using?
Gasket sealer
« Reply #3 on: August 01, 2013, 11:24:54 AM »
I use Hondabond 4 with no issues.
Gasket sealer
« Reply #4 on: August 01, 2013, 12:01:14 PM »
copy and paste info from threebond
( ThreeBond 1184 is a semi-drying liquid gasket whose major component is special synthetic rubber. After it is applied and dried, it will form a rubber-like elastic body. Since it excels in padding property, it shows a high sealing effect on bonded surfaces that have poor flatness and large clearance. In addition, it has excellent resistance to water, oil and gasoline.
Direct replacement for:
•Threebond 1104 (Discontinued because of hazardous chemicals)
•Threebond 1194 (Discontinued because of hazardous chemicals)
•Honda Bond
•YamaBond 4
•Suzuki 99000-31010
•Kawasaki Bond 56019-120 )
