Author Topic: What do you think?  (Read 16384 times)
Offline Felten
What do you think?
« on: August 09, 2016, 01:26:45 PM »
Hey all, just looking for honest opinions.  I recently purchased a 1989 TRX250R.  It has a K&N Filter & Outerwear Precharger, Keihin 39mm PWK Carb, Boyesen RAD Valve, Pro Design Cool Head, PTR "ELIMINATOR" Pipe and Quiet Fat Boy 2 Silencer.  I am 6'5 tall and weigh about 255 lbs.  Do you think I would be good to go to ride the Oregon dunes on this bike without blowing it up?  I only worry because of my weight and the resistance of the sand on the paddles.  I don't want to blow this bike if a t all possible.  Please let me know your thought when you have time.  Thanks, Pete
Offline huntertools
What do you think?
« Reply #1 on: August 09, 2016, 01:48:24 PM »
As long as it is jetted properly, ride it like as much as you like.
What do you think?
« Reply #2 on: August 09, 2016, 02:24:45 PM »
I agree with Huntertools. Make sure that it is jetted properly before you go. If you are unsure, make is very rich and change out the jets once you get there. You should take along main jets 150-185 with you. Then just change them as needed.
What do you think?
« Reply #3 on: August 09, 2016, 03:14:58 PM »
I'm a little bigger then you...give her hell!
What do you think?
« Reply #4 on: August 09, 2016, 03:41:03 PM »
You should be fine just make sure it's jetted good, what paddle are you going to run?
Offline Felten
What do you think?
« Reply #5 on: August 09, 2016, 04:01:07 PM »
Skeans1 - I have a set of 9 paddle haulers and a set of 8 paddle Sand Stars.  I am thinking the 9 paddle haulers would be to much hook up on the sand.
Offline Felten
What do you think?
« Reply #6 on: August 09, 2016, 04:03:57 PM »
rablack21 - Thanks for the advice.  I am not sure what you meant when you said "If you are unsure, make is very rich".  Are you saying it should be rich or not?  Thanks bud.
Offline jwraymond6
What do you think?
« Reply #7 on: August 09, 2016, 04:26:38 PM »
He meant jet it on the rich side to be safe and jet down as needed
Offline Felten
What do you think?
« Reply #8 on: August 09, 2016, 04:37:13 PM »
Quote from: jwraymond6;69159
 Gotcha!  Thx for the explanation.
Offline Felten
What do you think?
« Reply #9 on: August 09, 2016, 05:11:11 PM »
Since my carb is a Duncan Racing, pre-jetted Keihin 39mm PWK Carb, I wonder if they have a jetting / elevation chart?  Anyone know?
What do you think?
« Reply #10 on: August 09, 2016, 07:42:14 PM »
Cheap easy way to get some main jets is from Eddie Sanders with his jet wrench. Paddle 9 might be do able or could hook too much it's personal preference I like bite but I'm on the other end of the scale for weight. Another good option would be some Sand skate 2's if you can find a set they hook good as well as have some slip.
What do you think?
« Reply #11 on: August 09, 2016, 09:03:41 PM »
Take the float bowl off & see what main & pilot you have first before you get more jets. I weigh 180 & my bike has a similar setup with a 185 main jet. If you get jets stick to the upper 170's & 180's for the mains & 45-52 for the pilot, that range should get you dialed in out there.
What do you think?
« Reply #12 on: August 10, 2016, 12:10:38 PM »
You don't need to worry about your weight. I am 6'2" and 280lbs and I ride my 310 hard in the dunes. I run  9 paddle haulers and love them. I agree with the other fellas here that you should #1 figure out how your carb is jetted and #2 start off rich and work your way down. Good luck and happy duning.
Loren
Offline jwraymond6
What do you think?
« Reply #13 on: August 10, 2016, 12:34:55 PM »
I'm fat to lol I'd prefer the haulers over the Itp sand stars. The sand stars are a lot heavier than the haulers
Offline Felten
What do you think?
« Reply #14 on: August 15, 2016, 12:58:04 PM »
Quote from: broken1;69163
 Thanks for the information and advice!  I really appreciate it.
