Author Topic: Frozen carrier need help  (Read 8784 times)
Offline jto1
« Reply #15 on: August 15, 2016, 06:07:43 PM »
Quote from: broken1;69219
What carrier do you have in there, stock/aftermarket? Did the axle & axle bearings spin freely when you took the axle out? Just wondering if the axle bearings are bad & got the carrier hot enough to melt the PC inside the carrier housing?
Lonestar twin row, which was all new with only 5 hours ride time on it. No color on the axle or bearing races indicating it got hot, and they all still spin freely, and axle came right out by hand.
« Reply #16 on: August 15, 2016, 11:09:02 PM »
Maybe something to dissolve the powder coating. I would take it out of the frame before getting medieval on that bitch.
« Reply #17 on: August 16, 2016, 01:17:00 AM »
Quote from: jto1;69225
You wouldn't be worried about the side force from whacking it with a bfh? I'm a little nervous to go whacking away, afraid the side force may damage the bushings, or crack a weld on the frame.
I would not use a bfh. I would use a 3lb soft dead blow hammer. Actually I have access to a press so I would remove the swinger and press it out.
Offline dem3500
« Reply #18 on: August 16, 2016, 12:50:40 PM »
Quote from: rk88r;69227
aircraft stripper will do it. other than a paint stripper nothing that i have ever found will break down powder.
« Reply #19 on: August 17, 2016, 03:21:30 AM »
I would remove the swinger and press it out as well. Will all the effort you have already spent on this you would have already been done.
