Author Topic: Mikuni TMS  (Read 3912 times)
Offline The_Steve_Man
Mikuni TMS
« on: September 02, 2016, 07:32:29 AM »
@jerryhall are these good carbs? I see there are pro options that do away with the Jets but do they jet just like a normal carb? The reason I ask is I can get a new 39mm for about $100 and thought about getting one to mess with.
Mikuni TMS
« Reply #1 on: September 02, 2016, 02:31:42 PM »
I was not aware that Mikuni ever made a 39mm TMS, maybe someone bored this one.  The TMS series was discontinued many years ago, so I do not know if new slides, needles and float tower assemblies are still available.
I did not invest in all of the TMS & TMX needles, pilots and slides so that I could try to tune these carburetors.  These carburetors did not have an adjustable air correction or adjustable needle jets.  Not having the ability to change the air correction or needle jet limits how well a carburetor can be tailored to an engines specific needs and to the usable life span of the carburetor.  The Keihin PJ, PWK, PWM and Air Striker also lack these two adjustable circuits.
Mikuni TMS
« Reply #2 on: September 02, 2016, 02:55:38 PM »
Ok thanks. Jets R Us has them and said they bought out the last remaining inventory of the 39mm.
I run a TMX and really like it. O was just looking for a bigger one. I will probably just get one bored. I like being able to change the needle jets.
Sent from my MotoG3 using Tapatalk
Mikuni TMS
« Reply #3 on: September 02, 2016, 06:03:23 PM »
Quote from: The_Steve_Man;69376
The TMS and TMX slides do not interchange nor does the needles.  The needle jets are press-in on the TMX and TMS carbs and are not replaceable on the aftermarket TMS and TMX carbs
Mikuni TMS
« Reply #4 on: September 02, 2016, 06:16:04 PM »
I have a tmx off of a cr250 and the needle jet is replaceable. It has been very handy in tuning it.
Mikuni TMS
« Reply #5 on: September 03, 2016, 01:03:24 AM »
Does Honda offer different size needle jets for the OEM TMX carb?
Mikuni TMS
« Reply #6 on: September 03, 2016, 09:27:59 AM »
Quote from: Jerry Hall;69386
Only a few. S4, S7, S8, and S9.  I would have to look up the actual sizes but all I used is the 8 and 9. I don't if any other needles work in them. I oem needles from a 97,98 yz 125 and 01 and 02 cr250. This has worked for me so far.
