Author Topic: piston failure chart  (Read 28734 times)
« on: July 09, 2013, 10:12:25 PM »
[ATTACH=CONFIG]267[/ATTACH]
danhung11
  • Guest
« Reply #1 on: July 09, 2013, 10:41:24 PM »
Awesome chart, as crazy as it sounds for the subject!
« Reply #2 on: July 09, 2013, 10:56:58 PM »
well not really I can't get the picture large enough to read the small print :(
it is a PDF file that I converted but it killed the quality how do I attach PDF's
danhung11
  • Guest
« Reply #3 on: July 09, 2013, 11:04:43 PM »
Did you try uploading to photobucket, then attaching the IMG link?  If I hold down ctrl, and scroll up - I can read it fine at about 500% enlargement.
« Reply #4 on: July 09, 2013, 11:18:55 PM »
yes Dan the large image is photobucket and the small is attached, I can go as high as 400% on IE and its readable but not as nice as the PDF
Offline atvmxr
« Reply #5 on: July 10, 2013, 12:34:30 PM »
awesome!
that next to last one should read big end rod bearing let go (it does vaguely hint at a lower end problem) ....  I've had that bite me a couple times not realizing that was the issue only to destroy a new piston in a few minutes....
Offline trx250r88
« Reply #6 on: July 10, 2013, 10:44:35 PM »
Quote from: atvmxr;2505
awesome!
i had that happen last year too.the piston looked just like pic.rod bearing went,piston detnating on the edge.the motor still ran with major knocking noice.
« Reply #7 on: September 11, 2013, 10:51:49 PM »
