Author Topic: Opinions on my plug chop  (Read 6681 times)
Offline Grande huevos
« on: September 08, 2016, 10:17:47 AM »
Alright so Ive been struggling with getting this motor tuned properly. It's a 363 with 38 air Stryker I'm confident that I have the needle and pilot set properly because it feel crisp and responsive but when I get wit it feels very soft and a bit sputtery with a 200 main. I dropped the main down to a 190 and it feels MUCH better but I feel like I Could still go Down another size. My tempature never goes above 175* which is great but my plug looks very lean to me.   But as long as your temp is in check you shouldn't be able burn your piston up correct??
« Reply #1 on: September 08, 2016, 10:55:43 AM »
This was a brand new plug that I ran pretty hard for about 30 minutes with an outside temp of about 82*
Renegade 110 and maxim k2 premix 32/1   01 cr ignition
« Reply #2 on: September 10, 2016, 01:22:56 AM »
The porcelain cone of the dissected spark plug does not show any detonation that I can see,  The operating temperature of the porcelain cone is too cold.  I do not know if that is because the heat range is too cold or the combustion temperatures are not in the range where they should be when an engine is making close to maximum power.  You have cut off the most important part of the spark plug that tells experienced tuners about the heat range and combustion temperature.  Please do not destroy any more good spark plugs trying to find the optimum jetting.  Please read this link.   http://trx250r.org/threads/7326-More-power=67051&viewfull=1#post67051    I hope that it will prevent you from becoming another victim of another one of the very popular internet myths that are causing novice tuners to destroy pistons when trying to tune their engines using the spark plug dissection approach to jetting.
Show me the top of the piston.  I can tell you much more about where you are in your search for the main jet that will give you the highest power and whether your piston temperature is knocking on deaths door.
Coolant temperature has very little to do with burning a piston unless the engine package was not well designed and tested.  A well designed package will not be driven into detonation with 175 deg coolant temps.  A poorly designed package can experience detonation when coolant temps are at room temperature. A hole will not burn in the center of the top of the piston or burn off the edge of the piston on the exhaust port side unless the engine is experiencing detonation.
 Detonation will raise it's ugly head when one or more of the following conditions exist:
1.  The engine is too lean.
2.  The ignition timing is too advanced.
3.  The cylinder head design does not match the rest of the engine package.
4.  The exhaust pipe design does not match the rest of the engine package.
5.  The exhaust pipe discharge path has too much restriction.
6. The fuel's octane rating is below what the engine package requires.  You will never cause an engine to experience detonation by using fuel that has a higher octane rating than what the engine package requires.
« Last Edit: September 10, 2016, 01:48:57 AM by Jerry Hall »
« Reply #3 on: September 10, 2016, 10:35:36 AM »
Quote from: Jerry Hall;69487
This is the first plug I've ever cut because I keep reading to look at the base of porcelain.. I normally just look at the electrode.  My complete engine was built new by Pete @ Hybrid Engineering so I'm assuming all is up to par. I started by dialing in the air screw pilot and needle which feels great but it always seemed very sluggish up top with a 200 main. I couldn't  even pull the front end off the ground in 3rd or 4th gear and it felt sputtery so I dropped it to a 190 and that's where I'm Sitting now. The bike has woken up tons and feels great! Now she will stand up in 5th and the power comes on smooth all the way through.. The plug on the left is after 30 min hard ride with 190 main and the plug on the right is same jetting but with a 200 main.
Thea other pics are all of the 190 plug
Here is my piston after 14 hrs of running with the 200 main jet
« Last Edit: September 10, 2016, 10:47:13 AM by Grande huevos »
« Reply #4 on: September 10, 2016, 07:07:37 PM »
Attachment 11943
This is the error message I get when I try to open the above link
Invalid Attachment specified. If you followed a valid link, please notify the
administrator
« Reply #5 on: September 11, 2016, 12:20:36 PM »
« Reply #6 on: September 11, 2016, 06:03:01 PM »
Quote from: Grande huevos;69511
This piston crown shows no signs of detonation, the squish band is doing it's job and the temperature of the piston crown is in the safe zone.  If the piston clearance is where it should be for the power output of this engine and for the longest time span that you will ever spend at full throttle you are in the safe zone and should not have any problem with piston seizures.
All of the spark plugs shown look like your spark plug heat range is too cold for the type of riding you are doing.  Note the dark side on the tip of the porcelain insulator.  Screw the spark plug into the head.  The dark side is usually on the carburetor side of the engine. The dark side on the tip of the spark plug is because the dark spot on the porcelain tip is too cold to burn away the deposits. The side of the spark plug that is farthest from the exhaust port is bathed with cool fresh charge that has been traveling up the back cylinder wall.  When the tip is too cold, the rest of the porcelain is also too cold and the porcelain will accumulate deposits.  When a high performance engine runs without any sputtering or misfiring at wide open throttle and at high RPM, the porcelain tip of the spark plug will be white on a new spark plug with only a few minutes on it.  The porcelain cone that surrounds the center electrode will stay white or may turn color (light tan, yellow, brown, gray) as the spark plug experiences more time.  The color of the porcelain cone is influenced by the type of fuel and two stoke oil that is being used as well as the milage on the plug.
Do you have a picture of the piston crown after a hard ride with the 190 main jet.   I would like to see if the piston crown may be reaching its maximum safe temperature.
« Reply #7 on: September 11, 2016, 06:03:39 PM »
Do you have a picture of the piston crown after a hard ride with the 190 main jet  I would like to see if the piston crown may be reaching its maximum safe temperature.
